Capacity of van charging system?
Discussion in 'The Beginner' started by Touchwood, Feb 18, 2012.
  1. Touchwood
    Touchwood Funster
    Aug 23, 2011
    770
    736
    NE England
    So, I need a new habitation battery. The old one is a 120 AH battery, and I was planning to replace it with the same, but it occurs to me I ought to check if the van charging system has the capacity to cope with this?
    When I bought a battery charger recently to charge my boat leisure battery I had to pay more for one that had the capacity to charge a 100 AH battery - presumably the van system will have a limit - how do I find out what it is?
    Van is a Compass Avantgarde 400 RL, '02 plate. I'm not sure if the battery I'm replacing was the original or not.
    All advice welcomed, as usual.
    Mike
  2. scotjimland
    Jul 25, 2007
    29,040
    25,731
    Suffolk
    Within reason, the size of your battery bank won't be a problem..if you increase the battery ah it will just take longer to reach full charge ..
    For example...
    if it takes a 20A charger 5 hrs to charge a 100ah battery, it will take 10 hrs to charge a 200ah battery.
  3. Touchwood
    Touchwood Funster
    Aug 23, 2011
    770
    736
    NE England
    Thanks ScotJim.
    Not doubting you, but maybe I've been misinformed then? I understood that if the charger wasn't "man enough" it wouldn't charge at all.
  4. Gromett
    Gromett Funster
    Feb 27, 2011
    8,345
    15,798
    UK
    A lower capacity charger will just take longer.
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,368
    18,054
    YO11 2BD
    the original analogue power supply/charger in my RV was rated at 45amps to provide 12v power on hookup, but only 2 to 5amps were diverted to battery charging.......the battery bank is 440ah.
    to charge from 50% capacity would take around 44hrs but it worked.
    now replaced with a modern 45amp electronic 4 stage charger/power supply which will charge at up to 45amps on flat batteries.
  6. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,954
    Our Autoquest came with a 85Ah battery and I replaced it with a 110Ah. No problems with either of them.
  7. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,125
    3,541
    Eastbourne East Sussex
    As previously mentioned, regardless of the size of your battery bank it is still a nominal 12v. As long as the charger produces a higher voltage than the batteries it will charge them. A charger with a higher output (amps) will charge them faster but however titchy your charger it will get there eventually.:thumb:
  8. Touchwood
    Touchwood Funster
    Aug 23, 2011
    770
    736
    NE England
    Many thanks all.
    New 105 AH leisure battery bought from Autoplus in Norton - £69.00
    Really helpful staff and good prices, would recommend to anyone in this area.
    • Like it Like it x 2
  9. pappajohn
    Aug 26, 2007
    30,368
    18,054
    YO11 2BD
    good price but crap website. :Sad:
  10. Touchwood
    Touchwood Funster
    Aug 23, 2011
    770
    736
    NE England
    Hmm - never looked at the website Pappajohn. If I had, and it is as bad as you say, maybe I would have been put off - which goes to show something, I guess, not sure what!
    Edit: Had a look and you're right - absolutely useless website. I wonder if they know that the links don't work?
