Capacitor required (1 Viewer)
Dec 12, 2010
5,367
21,177
Cumbria
since 2011
Switched on my ultrasound cleaner which worked fine for 10 minutes then it started spewing out smoke ! So a capacitor has blown apart, anyone know where I can identify and obtain a replacement. It looks like the value is .22 uf and rated 400v/220v.
laird of Dunstan
1,464
3,953
lincolnshire
Rapido 9000DFH
ex caravanner
Rs have a huge warehouse at Corby or there is shop in Peterborough called maplins that hold lots of electronic spares
tonka
10,795
21,440
Cannock, Staffs
A class Burstner 800
Since 2000
Do you want me to upset you...
I had one of those ultrasound cleaners that my son was given to him from work.. He gave it me and I dont know why as never used or needed one.. Sold it Monday at the boot sale... £5..
Just looked them up and seen the prices :Eeek: someone had a real bargain.
jockaneezer
Dec 12, 2010
5,367
21,177
Cumbria
since 2011
Thanks for the suggestions, hopefully ordered the correct one from Maplin, £1.59 and a 3 day delivery to my local shop. Anyone know if these things are polarity sensitive and if so, how do I tell the orientation of the original unit that's still on the board ?
@tonka, I got mine from work too, it's a nice small industrial unit, much better than those "jewellry cleaners" you see advertised. I'm going to use it to try and clean a Mikuni cabuerettor off my log splitter, one of the jets was blocked which I managed to blow out, but I suspect the drilled pasageways for the pilot air screw may be blocked as I can't get it to tickover very well, it's always "hunting" but settles down with a tiny bit of choke.
Feb 27, 2011
14,669
74,857
UK
Self Build
It looks like it was probably an X2 capacitor which means it goes across the line in an AC circuit. With it being for an AC circuit I doubt it will have a polarity but check the packaging.
Don't take my word for it though, my electronics knowledge is dated.
Louis
1,204
982
Anglesey
Fiat Ducato Auotrail
6 Months with motorhome(35 years tugging)
Why does anyone want to clean ultrasound?
How does it get dirty?
JJ :cool:
Incorrect sorry
Louis
1,204
982
Anglesey
Polarity marked on the black lines
jockaneezer
Dec 12, 2010
5,367
21,177
Cumbria
since 2011
Yup, it's on the can type capacitors, but it's the rectangular yellow one in the middle that's needing replaced. Incidentally, the bath kept working even as the smoke was billowing out, it looked like a hi-tech witch's cauldron :LOL:
Louis
1,204
982
Anglesey
Aha - then I'm stuffed, unless it's distinguishable on the underside (n):notworthy:
Mar 26, 2009
8,130
11,168
Yr Wyddgrug
Hymer B678DL
Since 2009
When the replacement part arrives ask google to find a datasheet for that component part number. That should tell you all you need to know regarding polarity..
