Can you have a solar panel with no controller?
Discussion in 'Solar Power' started by Cossieg, Nov 9, 2015.
  1. Cossieg
    Cossieg Funster
    Jan 25, 2013
    200
    96
    Yate for the summer!
    Friend has been finding his fridge tripping out at about the same time each day, around 1pm. Local company have had a look and reckon that the solar panel is connected directly to the leisure batteries and the high voltage generated at 1pm when the sun is strongest is tripping the fridge. The van is a 2007 Adria and the panel was fitted by the supplying dealer. Friend claims they've been right through the van and checked the wiring but can't find anything like a solar controller of any sort. Is it possible that a dealer would fit a solar panel with no controller and what would be the affect on the batteries if this happened? It's been like it since 2007!
    Local company are fitting a solar controller tomorrow.
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,107
    14,921
    Leeds the one up North
    So were do the wires from the panel connect? having traced them
  3. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,578
    5,644
    West Sussex
    It will fry the batteries, in bright sun depending on load the voltage from the solar panel will be between 16-21 volts. Some charging systems have a solar regulator built in if the panel is wired into the charger this could be the reason he can't find one, if it the case it's probably faulty.
  4. Techno
    Jul 28, 2010
    14,107
    14,921
    Best way to prove it is to disconnect the panel were you think it is connected and measure the voltage on the ends. If there is no regulator is will be close to 23 volts in bright Sun
    Edit 21.5volts
    • Like Like x 1
  5. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,213
    12,578
    goole
    In short no and they don't cost that much mane thing to remember last thing to connect is the solar
    first thing to disconnect solar or you will burn out the controller
    BILL
  6. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,702
    11,858
    Plympton, Devon
    The answer to the question is yes, in the sense it could be done. There is a type of controller called a shunt controller which effectively does just that, connects the panel directly across the battery terminals. It isn't the most efficient way of doing it but these controllers are clever enough to disconnect the panel when the battery voltage becomes too high.
    No controller means no disconnect so bad installation.
    • Like Like x 1
  7. Cossieg
    Cossieg Funster
    Jan 25, 2013
    200
    96
    Seems the panel is wired directly to the batteries and the voltage measured was something like 20v! Could it have been like this since 2007 and not fried the batteries or other damage?
  8. Techno
    Jul 28, 2010
    14,107
    14,921
    If the disconnected open circuit voltage is over 20 yes there is no regulator. When connected it can be delivering 18 volts closed circuit so yes it will damage electronic components
  9. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,578
    5,644
    West Sussex
    The batteries would have fried in a few weeks, if wet cells they would need constant topping up if sealed the emergency pressure valve would have vented , either way then would be dead in a very short time.
    Edit:
    l would have thought he would have noticed a strong sulpher smell.
    Don't see how it could have been like it for 8 years without noticing unless the van has spent most of it's life in covered storage.
  10. Techno
    Jul 28, 2010
    14,107
    14,921
    I think that would depend on how much current the panel is producing and how much load on the batteries
  11. Techno
    Jul 28, 2010
    14,107
    14,921
    If he's running a compressor fridge all the time it will drop the voltage
  12. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,578
    5,644
    West Sussex
    True OP hasn't said what size panel, if 20 watt or less wouldn't cause much of a problem.
    Much bigger type of fridge wouldn't matter when the van is not in use and only a couple of hundred millamp drain on the electrics.
    Edit: Just noticed Andy said "running fridge all the time" , but 8 years continuious on a camping fridge!
    • Funny Funny x 1
  13. Cossieg
    Cossieg Funster
    Jan 25, 2013
    200
    96
    Not sure of the size of the solar panel but do know that he has a standard motorhome type fridge so not a compressor type. Get the feeling that people think that without a regulator this couldn't have lasted this long? Friend does wild camp and does use sites so a mix of uses but the leisure batteries are as old as the van. I'm just v surprised that a dealer would fit a panel without a regulator but he can't find anything and the output voltage is v high.
  14. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,578
    5,644
    West Sussex
    Dometic fridges have a solar input, could the 12v be wired into that as that would hold the voltage down when not running on gas. It is not normal practice unless you have loads of solar power and a big battery bank.
    • Like Like x 1
  15. chaser
    chaser Funster
    Feb 16, 2013
    7,314
    8,030
    uttoxeter
    One of the first things , if it is now disconnected is the fridge still going off but if it's a normal fridge it shouldn't work off the leasure battery on 12 volt surely
  16. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,801
    1,025
    Cark, Cumbria
    If,like our Adria, it is "pre-wired" for solar it may appear that there is no regulator.
    Ours has the Schaudt LR1218 fitted under the false floor next to the charger/controler.
    There is also an "extra" fuse on the charger which can be inserted to make the fridge run on 12v permanantly. We find this useful on channel crossings.
    • Like Like x 1
  17. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,815
    1,882
    Warwickshire
    Sorry to hijack the thread, but can you explain this please - where is this 'extra' fuse and where is it located on the EBL?
  18. DP_JAY
    Mar 17, 2010
    1,801
    1,025
    Cark, Cumbria
    If I remember correctly it is the fourth fuse from the left on our EBL226 & is highlighted in yellow.
  19. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,815
    1,882
    Warwickshire
    That is the AES Refrigerator fuse - I presume you have an AES fridge? It is not used with manual selection fridges but my understanding is that it should be present all the time if you have an AES fridge.
    • Like Like x 1
  20. Stroppy Bird
    Stroppy Bird Funster
    Mar 11, 2014
    417
    390
    Lincs
    Mine is the same. It took me ages to work out why my fridge (not AES) would keep on going on 12v after switching the engine off. I eventually traced it to a fuse being in the AES fridge slot and problem solved. Unfortunately I had killed my battery off one too many times and had to change it. I'd be very careful about having a fuse in that slot if your fridge is not AES.
