can i use a solar panel on a gel battery (1 Viewer)
dellybaby
5
chingford
adria 571 coral
im a newbie
Hi I have just bought 120w solar panel I was told by maplins, I could use this on my gel battery but have since read on a thread I goggled that you can nott use a solar panel, or is it certain solar panels, Normally I find google helps but sometimes you get so many conflicting answers im now unsure. my battery is a exide g85 gel battery , so does anyone know if this is true thanks adele
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
You simply need a solar regulator that has a selection of battery types in its set up menu.
These are quite common
Example, same as a Steca but half the price
Link Removed
D
dellybaby
5
chingford
adria 571 coral
im a newbie
solar regulator
Hi I have a 10a 12v regulator I got in the solar panel kit
Link Removed is this no good
43,301
49,287
good question, and one i dont know the answer to. :Sad:
but i will say a Gell or AGM battery has a different charge regime to a standard lead acid battery.
slightly higher voltage (14.5v+) is needed for Gell/AGM to be fully charged.
someone who does know will be along to help.
Techno
Jul 28, 2010
15,475
20,756
May 2010
There is no product information on the maplin supplied regulator in that link so I cannot confirm whether it is suitable or not
Techno
Jul 28, 2010
15,475
20,756
May 2010
Bulk charge tends to be the same across all battery types but Gel has a higher float charge by 0.5 volts over a vented battery or 0.3 volts higher than a sealed type.
reader
185
73
IO83rk
Do you rate the Steca regulators Techno ? I am replacing mine and was considering the PR1010
Techno
Jul 28, 2010
15,475
20,756
May 2010
Not at Steca prices no.
How much are you contemplating paying for it?
Cheapest I can see on ebay is £78
The 30 amp I posted earlier is cheaper Fangpusun make em anyway
Techno
Jul 28, 2010
15,475
20,756
May 2010
If thats the price range you're into?
spend it on this, offer £75
Link Removed
Mine
Link Removed
D
dellybaby
5
chingford
adria 571 coral
im a newbie
Hi it says on the front solar input 10a max overcharge 14.0-14.5v. over discharge 11+ - 0.3v I am new to all this, so dont understand. I got sent this with my 120w panel kit, does this mean i have to use a 10a one or a 30 a like the link you sent. my battery is a exide g85 sealed.
Techno
Jul 28, 2010
15,475
20,756
May 2010
10 amp is suitable for that panel but there is no detail of the charging regime, I would suggest it's OK but you get what you pay for.
Most of the time your battery will get a good charge from alternator or hook up so the solar is a bonus even if it doesn,t chart at optimum.
Aug 29, 2010
845
1,244
Nuneaton. Only when I have to.
Hymer Exsis t564
Since Sept 2010
Hmmm, I have just replaced my 4 stage battery charger and was advised to choose the same algorithm for an AGM battery as the one for lead acid. The alternative being the gel algorithm.
Isn't an AGM battery, in effect, the same as a lead acid?
Techno
Jul 28, 2010
15,475
20,756
May 2010
My mppt regulator
D
dellybaby
5
chingford
adria 571 coral
im a newbie
hi I have bought the solar panels so i can stay longer when wild camping, when im at festivals, I will not have hook up or be moving the mh for at least 4 days, so you saying i need to buy a higher amp like 30 to use my panels for daily use, to re charge my battery. sorry for the questions, but im unsure thanks Adele
Techno
Jul 28, 2010
15,475
20,756
May 2010
NO the 30 amp is the current handling capacity, nothing to do with the charging voltages.
Your panel wont produce anywhere near 10 amps so the unit you have is fine in terms of current carrying capacity but it doesn't charge at a rate specific to gel type batteries rather it must be assumed that it charges at a compromise in relation to the possible battery types
Incamania
47
27
Preston
Since 2002
Solar Panel to charge a Gel Battery
Hi Dellybaby
As you've bought your 'kit' from Maplin visit their site and if my memory serves me correctly you can post a 'help note' to their technical department and they will reply on that site.
The other option is to ring Maplin ask for Tech Help and a Techman will answer your question there and then. I have done this in the past and found them very knowledgeable and helpful.
ATB
Incamania
:thumb:
Techno
Jul 28, 2010
15,475
20,756
May 2010
That's very good it confirms the higher float charge requirement :thumb:
maz
Jan 26, 2011
4,460
7,737
Bizeljsko, Slovenia
N+B Arto
Since March 2011
General rule seems to be that if the blurb about a solar regulator doesn't specifically state that it has a setting for gel batteries then it probably won't work properly with them. But as others have said, ring Maplins and check the spec.
I had a problem when a dealer fitted solar panels and a regulator that wasn't suitable for gel batteries to my gel battery equipped van. Batteries just would not charge properly. Got round it by changing the batteries to normal lead acid which I prefer anyway. If your regulator turns out to be non-gel and your battery is on the old side, maybe swap it for the wet type as a way round the problem?
