Can I change these lights...? (1 Viewer)
Jul 2, 2011
953
492
UK
Swift Kon Tiki Tag, 2007.
Newbie
Having changed some spot lights to LED, the rest of the lights look yellow and dim, but the rest are these (see pics), I assume the bulb pulls out to replace, but not sure if I can do anything with the light/bulb to make them.
Link Removed
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Assuming it's 12V that is a standard fitting, you look for the Side Entry/Pins type.
You might just have to remove the reflector to make it fit.
Encantador
Jul 2, 2011
953
492
UK
Newbie
Thanks, I assume you have to take the bulb out and check the wattage abuy the LED the same. is that correct?
Steve
ShiftZZ
21,383
84,499
Dark Side of the Moon
It looks like a G4 LED..
Same as what Graham said,,, but here at £1.95 delivered, I have had delivered 11..
Link Removed
Next day delivery....
Heyupluv
3,862
1,593
France,
touring many years..42+
You should be able to change them. You need a LED bulb with side pins (similar to This One) rather than back pins (like This One).
I agree with GJH and ReallyRetired and shiftzz.....look to see if there is a large thin spring clip around the inside rim,
Mel:thumb:
ShiftZZ
21,383
84,499
I found that the bulbs that we had were 10w and the replacement were 0.9w so we had 12 to replace, so in essence the cost of running all the new ones is the same as running one of the old ones...
GJH
29,450
38,827
None, now sold
2006 to 2022
Steve
Not quite. It's bulb equivalent (G4 in your case) rather than wattage. The big point about LEDs is that the wattage is so much less so saves so much power.
Encantador
Jul 2, 2011
953
492
UK
Newbie
Have taken one out, it is a G4 (max 10W), having removed the bulb and looking at the photos of the LED ones it does look as the shape of the reflector might be an issue, and no obvious way to remove it, no spring clip.
Apr 27, 2008
11,842
14,066
Eastbourne East Sussex
Hymer low profile
Since 1972
The reflector shouldn't be a problem, obviously the LEDs don't need the reflector so could remove it if necessary, mine are still there with the LEDs though.
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
I fitted G4 LED lamps into our existing spots.
It looked as though it would be tight but I just trimmed sufficient length off the pins on the LED lamps, so that they fitted with the Reflector remaining in place.
Callum
