Can anyone help with gas bottle conections (1 Viewer)
Kevfromwales
30
Gloucester
Hi Top
Got a new van with built in gas regulator and screw
Connection for propane bottle which I have, also I
Have a butane bottle dose any know if you can a
Connector to convert it to fit a screw on
:thumb:
43,323
49,422
hi kev,
yes you can but it means changing the pigtail hose as well
Link Removed
first reg adaptor in list and last hose in list.
not worth the hastle really.
ubuntu1
155
44
Derbyshire
PVC
since 2006
gas
I would go to your gas supplier and change the butane bottle for a propane one.
dellwood33
878
Newcastle
italian crap
too long
I agree - I have just fitted 2 gaslow Propane pigtails & a manual changeover to my van and swapped the Butane cylinders for Propane. Having one type of bottle just simplifies things IMOH :Smile:
iceni
300
117
Birmingham
Lowline Coachbuilt
27yrs
Hi kev
propane is better tan butane generally as it doent freeze at )degc like butaneb does. It also burns a bit hotter so is better for cooking and heating - no it wont hurt your appliances as they have been desined around propane.
As others suggest consider fitting a refillable (gaslow) bottle which means you can refilll with gas from an lpg outlet at a garage which is a lot cheaper and you dont have to wait till its empty. you could keep the propane as a standby.
Phill
ips
506
4
Low profile
Have always camped, caravaned or had boats. Now in our second year with the motorhome.
Why do you want to use butane any way ???
Oct 14, 2007
3,985
6,244
Rochester
Auto-Trail Mohawk
16 fun filled years
Which gas should I use, Propane or Butane?
The physical properties of the two gases are very similar, and when regulated to the correct pressure, they will perform almost identically. However there are some important differences.
Of the two gases, Butane has the most advantages.
  • It is less toxic and so can legally be used and stored indoors. Litre for litre, it contains around 12% more energy than Propane and so you can squeeze more running time into the same sized bottle. (Butane is heavier than Propane though, so weight for weight it's a pretty close call.)
  • Butane also burns cleaner than Propane (although this isn't normally a serious issue in caravanning.)
  • Finally, while it's not strictly a property of the gas, Butane canisters generally use clip-on type connections. These are far more convenient than the Propane screw type connections, especially if you swap bottles around regularly (as you might if you also use your caravan bottle to run a barbecue.)
Conversely, Propane has only one advantage over Butane - but it's a big one!
  • In order to be usable, the liquid in the bottle must be able to boil into a gas. In the case of Butane, this will happen at any temperature above -2C, whereas with Propane, this figure is much lower, at -42C. In the real world, it's not so clear cut. Whenever some of the liquid boils into gas, the remaining liquid cools. It is therefore possible for the temperature of the liquid to drop to several degrees below ambient. This can easily prevent a Butane canister from producing a useful gas supply, even when the outside temperature is several degrees above 0C. A compromise can be reached by mixing Propane with Butane, but as far as I'm aware, none of the UK 'big bottle' suppliers actually do this. The small gas cartridges that are produced for camping stoves and gas lamps are often Propane/Butane mixes. So choosing the right gas pretty much boils down to whether you need to use it in freezing (or near freezing) conditions. If this is likely, then Propane is a must. If not, then Butane has the edge.
