Can anyone help with a mystery switch please? (1 Viewer)
Debs
6,299
181,473
West Notts
A class Adria Vision
Sorry the pic is a bit blurred but does anyone have an idea what the switch to the right of the steering wheel is. It only lights when the igition is on?
We found another one on the side of a locker but have found this is for heating the waste water tank.
movan
21,492
120,753
Moving around
Burstner
since07
I have one. It is something to do with telling you your alarm is working I think. Mine blinks when I set the alarm.... however, I am sure it is supposed t stay on all the time to deter thieves. Hopefully, if I am wrong ... as per norm...:) someone will come along soon. x
kelv
672
895
leicester
Carthago 145
I have a switch in the same place and it is to activate tracker movement sensor
Debs
Debs
6,299
181,473
West Notts
Hmm ok thanks both.... Joy we don't have an alarm as far as we know, wonder if it's had a tracker at some point, there's nothing in the paperwork for one.
I don't suppose there's any way of finding out - will there be another unit fitted somewhere?
13,072
101,433
Bolsover, Derbyshire
Hymer S800
not long enough
Is it a switch or just a light?
If a switch be brave, turn it off see what doesn't happen any more :D
It is odd to have anything with a light so low down where you cant see it
lorger
9,660
90,501
Dumfries
Knaus Sun 650MEG
Does the wee red light press in like a button, we have one like that on the dash and you can press the light to change settings
Debs
Debs
6,299
181,473
West Notts
Is rocker switch the right description? It's a definate switch off/on but only lights when the ignition is on.
Not sure if/how long it stays on - we're just sitting out the heavy rain/wind. Will have to have a play when it's dry to see if it's to do with the lights.
It looks exactly like this one but we have discovered that the waste tank heater.
Debs
Debs
6,299
181,473
West Notts
We have, several times, nothing apparently:cool:
But wondering about kelvs or lorgers suggestions.
Actually lorger which settings are you referring to? It's on a renault base and we have been trying to work out how to get the clock to display on the dash
kelv
672
895
leicester
Carthago 145
I have the exact same switch on my hymer when they fitted the tracker this switch appeared I asked what it was for and they said switch it on when not using the motorhome so tracker people can sense any movement from unwanted guests. Phantom tracker must be activated for switch to work.
Debs
Debs
6,299
181,473
West Notts
Ok thanks kelv - we took it they were after market fit, not sure where to go from here.... It has finally stopped raining so we'll be able to have another prod and poke around(y)
99
65
Cheltenham
Low profile
On the strike back alarm they fit a button which turns on/off the security loop for bikes ect. The loop comes as a extra and attached to the system at the rear of the van.
movan
21,492
120,753
Moving around
Burstner
since07
Thank you. I wondered what my button was for too.. you have now told me .. whey hey. :)
Debs
Debs
6,299
181,473
West Notts
Glad someone's getting sorted - we're still no wiser:think:....re-reading kelvs suggestion don't think it could've been a tracker as the switch only lights when the ignition is turned
We'll still keep fiddling:smiley:
FULL TIMER
795
717
NORWICH
SELF BUILT IVECO 75E17
BEEN BUILDING THEM FOR 32 years
could also be a switch for the supply to the fridge when using the camper leave it so it lights up when engine running, if you don't need to keep the fridge cool just turn it off , they often used to be fitted when using lucas 33ra relay's to interrupt the wire from C3 to the fridge via a lower rated relay http://www.autoelectricalspares.co.uk/lucas-srb630-33441-33ra-12v-60a-split-charge-relay-1583-p.asp I have also seen them used as a switch to operate the relay sending a 12v supply to W1 instead of connecting to the alternator, with this set up your leisure battery will not get charged and fridge will not work unless the switch is on.
Badknee
7,407
412,404
notloB
Vantage Neo
Living the dream.
See if you can follow the wires, may mean you standing on your head though lol.
887
1,045
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
My strikeback has a switch (without the light) so that you can turn off the external "bleeper" that sounds when you set the alarm. I have a loop for the bikerack but haven't used it as yet. Must give it a try.
iceni
300
117
Birmingham
Lowline Coachbuilt
27yrs
Is it a swich that overided the auto turn off of the lights when you take the key out. There will be some situations when you want to leave the lights on but with no engine running. theolder peugeots used to have a switch that left the sidelights on Phill
Debs
Debs
6,299
181,473
West Notts
Thanks for your replies everyone - still looking......it's a thin, single cable (comparable with a single piece of bell wire) and runs over to the passenger side and disappears through the bulk head in the passenger well (so oh says lol)
Just having a cuppa then will have a peek under the bonnet
movan
21,492
120,753
Moving around
Burstner
since07
If you have a button on your alarm switch that you point at the van.... try standing in the van and pointing it at the light button on dash and holding down the button in your hand for three seconds... What happens?
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
So anyone nicking your van only has to switch it off and you won't know the vans moved, that doesn't sound right to me.:think:
Debs
Debs
6,299
181,473
West Notts
Sorry got distracted:)
We're on our first trip out in 1st mh...... went a pootle to Calshot to see the liners going out....and called at The Red Lion for tea to spend our last xmas vouchers:LOL:
Will investigate more in the morning
God it's great innit this motorhoming lark(y)
Ps promise to stop pressing the switch till morning:)
haganap
12,757
26,436
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
If it is a British van it could be a 12v override like I have fitted on mine. Put your step out, turn the engine over, the step should go in... Switch the switch and try it again, if the step stays out I'm tight.
kelv
672
895
leicester
Carthago 145
The switch stops the van being moved without breaking in it does not disable the tracker ie lifted or towed
buckby
213
147
nottinghamshire
coachbuilt
The switch turns off the internal movements sensors on the alarm you press it then get out and arm the alarm if you have pets it will stop the alarm going off when they move about in the van on my 57 plate ducato you can do the same by pressing the arm button then pressing it again I have learnt this by getting half way to the toilet block for a shower then hearing my alarm going off because the dog has got up on the drivers seat hope this helps.
Badknee
7,407
412,404
notloB
Vantage Neo
Living the dream.
While looking for the weight plate on Mo I found all sorts of switches and wires lol.
Debs
Debs
6,299
181,473
West Notts
We've not long got back home from the New Forest. Loved it, wanna go away again asap(y)
We were told there's no alarm - so stupid question how do we know if there is one:oops:.
Debs
Debs
6,299
181,473
West Notts
Well we found out - some spotlights had been fitted, it's for them:doh::laughing:
Odd place though for the switch as you can't see it when in the drivers seat.
And if it hadn't have been raining/blowing/thunderstorms so much whilst we were away we'd have worked it out quicker:whistle2::blush:
Thanks for everyones suggestions though:Smile:
