Can any one tell me how to locate (and change) the pump in an Avantgarde 150?
Discussion in 'Tech/Mech General' started by grymbo, Jun 13, 2014.
  1. grymbo
    grymbo Funster
    Jul 30, 2013
    43
    13
    South Ayrshire
    This being a follow on from my recent post regarding a failed water pump. Great advice given for previouse queery but having spent the afternoon between crawling through and under the van and running back and fourth between tinterweb I am no further forward. It would however be fair to say I am by now exasperated:thumbdown:.
    Any advice would be greatly appreacaited.
    Grymbo.
  2. chaser
    chaser Funster
    Feb 16, 2013
    7,701
    8,763
    uttoxeter
    Don't know if yours is same as ours but it's under the plastic cover on the left of the engine looking from the front , the same one that covers your cambelt that runs your pump. Hth
  3. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    You may get a few more replies if you state the year and engine in your van
  4. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,607
    3,419
    Telford, Shropshire
    Assuming you mean the habitation water pump and not the engine coolant water pump, it sohlud be in the water tank. I'm fairly sure Compass along with Elddis (AKA Explorer group) use submersible pumps in the tank. Quite often the water tank is in the bottom of the wardrobe.
    D.
  5. chaser
    chaser Funster
    Feb 16, 2013
    7,701
    8,763
    uttoxeter
    Right , put me right there, yes in the bottom of the wardrobe there is a piece of ply with a hole in , pull that up and feel for a big lid on top of the tank , unscrew it and pull the pump out with the cable, simples, thinking about it I think you have to remove the piece of ply that stands up as well, four screws I think, havnt had it off for a bit:Doh:
  6. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,967
    The habitation water pump in our Autoquest was in the tank but, as far as I remember, it was fixed in some way by clips so would need to be released before being extracted as Chaser says.
  7. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    796
    646
    Wet and cold place outside of M25
    Pump
    I have an 08 Elddis it is designated as a Sunstyle 140, very similiar to an avantgarde except I have a locker access from the outside, next to the battery locker.
    In the bottom of the wardrobe is what I thought was my hot water boiler. the tank is slung underneath the floor with I assume the submersible pump inside, how you get at the pump I haven't a clue. another of those mysteries awaiting me.
    I know this may not really help, good luck :Smile:
