Can A Heki Roof Vent (between Inner/outer Plastic) Be Cleaned? (1 Viewer)
Jul 31, 2014
1,930
3,241
West Yorkshire
EuraMobil Activa 820HS
Hi all
Is it possible to clean a Heki roof vent between the inner & outer plastic coverings?
I have a roof vent in the bathroom which has two side handles to push upwards to open the vent.
It's the model whereby the whole vent moves up squarely to let air flow through the gap - you can't open it so that you can see the sky. (Mini Heki Airquad)
The square plastic cover is in two parts - the inner part has vents moulded into it and the outer part doesn't have and is in affect the cover.
Trouble is, dirt has formed between the vents on the inner and between the inner and outer cover.
Although it still does its job, it does look unsightly.
Does anyone have a mini Heki Airquad, or anyone know if the inner & outer roof square cover comes apart easily to aid cleaning? Or is the cover a complete unit?
Thanks a lot
scotjimland
2,324
10,044
A Woosh bang
have a look at it from outside up on the roof..
if it has four screws, these can be undone and the cover removed and separated for washing
