campervan toilet problem
Discussion in 'Motorhome Chat' started by mcnab47, Feb 7, 2016.
  1. mcnab47
    mcnab47
    Feb 7, 2016
    3
    co antrim northern ireland
    have a thetford cassette toilet C2 i think its leaking water from the flush tank and the knob to flush the toilet is nearly impossible to turn it flushes okay so nothing wrong with the pump , the blade opens easy enough on the waste tank. Any help appreciated, have looked at all diagrams i can find but they dont show the tube from the pump to the flush.
    • Thanks Thanks x 1
  2. Fletton
    Fletton Funster
    Oct 19, 2014
    710
    2,685
    Nth East Lincs
    Bump.. :)
  3. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,179
    3,014
    Kendal, Cumbria
    Remove upper knob and shaft. You'll find the part of the shaft that connects with the cassette 'knob' has split. Not expensive or difficult to repair. The Thetford site has split drawings etc.
    • Like it Like it x 1
  4. Wickolad
    Wickolad Funster
    Sep 10, 2013
    481
    533
    Wickersley
    I found this exploded diagram of thetford c4 shows location of flush pipe, also pic/ price of c2 flush pipe you can see where it's located on exploded diagram image.png image.png
    Hope this helps, you can view all at leisure shop direct website, I believe thetford c2, 3 and 4 are pretty much the same build.
    Lance
    • Useful Useful x 1
  5. mcnab47
    mcnab47
    Feb 7, 2016
    3
  6. mcnab47
    mcnab47
    Feb 7, 2016
    3
    thanks to everybody who replied. hope i can sort this
  7. Wickolad
    Wickolad Funster
    Sep 10, 2013
    481
    533
    Wickersley
    Put a bit of pink toilet fluid in toilet flush header, then you have a better idea where it may be leaking.
  8. JFD
    JFD Funster
    Apr 9, 2015
    122
    71
    Surrey
    If you look at the leisureshopdirect.com website, and drill down to water, then caravan toilets, then Thetford cassette toilets, then (still with me?) Thetford C2............, you will find several downloadable instruction sheets that will help you sort out your issues - at least they did for me when I struggled with a C2 in my last motor home!!!
