Campercontact offline maps (1 Viewer)
Muddibootz
166
114
North Shropshire
Elddis Autoquest
since 1994
A few days ago, I bought the full version of the Campercontact app for Android and it seems to be a really useful tool. However, when I try to download any offline maps, I get an error in the download immediately after pressing Yes to confirm the download. This happens for all offline maps. I have more than enough storage on both internal memory and my broadband is working fine.
I've looked all over the campercontact website for help and tried to contact them but got no response. Anyone else use this and had similar issues?
R
Robert Clark
Try fully uninstalling and re installing the App
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
You have to be on WiFi to download I think.
R
Robert Clark
Thanks - I'll give that a try
Can you see the online maps with all the thousands of campsites on?
If not you may have to press the 'upgrade to full option' again to validate your purchase
Muddibootz
Muddibootz
166
114
North Shropshire
Elddis Autoquest
since 1994
Yes - I see the online maps ok and I can see all the campsites within the app ok. It comes up "Already Bought" when I attempt to upgrade but even after an install, it fails to download maps.
I noticed that I can "route" to a site via other apps and downloaded Sygic which seemed to work ok so I guess I can use that one if I don't ever get the maps to load although it doesn't help when browsing for sites.
Thanks again for your help. Much more help on here than through Campercontact.
Oct 18, 2014
1,858
1,157
Salisbury
Hymer B598 PL
Since 2013
Strange, they usually respond quite quickly to emails
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
Can I just check you are downloading the maps correctly? You click on the "i" symbol then on the page which opens select the offline maps button. Then slide the button across for the country you want to download the map of which should open another little window from which you can select "Yes". This is working on mine because I've just tried it.
Muddibootz
Muddibootz
166
114
North Shropshire
Elddis Autoquest
since 1994
Can I just check you are downloading the maps correctly? You click on the "i" symbol then on the page which opens select the offline maps button. Then slide the button across which should open another little window from which you can select "Yes". This is working on mine because I've just tried it.
Yes - that's what I've been doing. It seems to try to open what I assume would be a download progress box but then immediately closes this and presents an error. It doesn't give a reason. It just says try later (which I have).
Reactions: DBK
scotjimland
2,324
10,044
A Woosh bang
Also just checked..
it downloaded a map no problem
Muddibootz
Muddibootz
166
114
North Shropshire
Elddis Autoquest
since 1994
Also just checked..
Thanks. That rules out any issues at their end, so it's definitely something on my device. I think I read somewhere that you can load it on two devices so I'll see if I can load it on my old phone. I need a new memory card first though.
scotjimland
2,324
10,044
A Woosh bang
is this information pertinent ?
Android
Devices: Android smartphones and tablets.
Warning: not all devices are supported. We note that often the 'cheaper' devices have trouble running the app. Think of cheap Chinese devices or devices from Empire or Cresta.
Software: Android 4.0 and higher
Which Android version do I have?
  1. Go to the settings of your device.
  2. Go to 'Device information' or 'About this device' (or something similar).
  3. In this list you will find the Android version.
http://www.campercontact.com/en/content/Compatibel Campercontact-app
Reactions: DBK
Muddibootz
Muddibootz
166
114
North Shropshire
Elddis Autoquest
since 1994
Android
Thanks - I wondered that too but I'm running Android 5 on an ASUS tablet so thought it should be ok. It seems to run the app fine, it's just the offline maps seem to be a problem.
Sep 10, 2012
2,133
3,714
worcester
Sunliving van
As already suggested delete the app from the Asus then reinstall from plastore ( it will know u have already paid)
If that don't fix it then a setting on the Asus because I just downloaded an offline map on mine.
Muddibootz
Muddibootz
166
114
North Shropshire
Elddis Autoquest
since 1994
Thanks. I've re-installed a couple of times now. It downloads the photos ok each time and performs the update check ok. It also picks up that I've already paid for the full version but it just doesn't like the maps. I can't think what else to check on the ASUS so I guess I need to wait for a response from campercontact for a few clues as everything else seems to work fine.
