Camos Crank Up (1 Viewer)
Big Nick
260
290
Yorkshire
Low Profile Coachbuilt
Newbie
I've just bought one of these and am really impressed with it.
I ummed and arred for ages as many were saying go for a Snipe as its not much more but I found it was nearly double the price!!
I got it fitted at Dave Newells who matched the cheapest online price and did a great job of hiding it all in the wardrobe and fitted an inline signal meter
A quick look on YouTube and I had it tuned to Astra 2 in just over a minute for Freesat reception on my Avtex tv by 9 turns on elevation, using a compass to point it south then gradually moving east until the signal meter tone changed to high and the picture came on
A great product, very easy to use and probably the cheapest permanent roof mounted satellite system out there
Nov 2, 2008
461
377
Lincolnshire
PVC, S&L Iveco
45 years
Yes we have had ours for eight years now and been totally reliable. You just have to remember which way you turned it so you put it back the same way or the cable would be trapped. Good in wind as well.
May 12, 2011
1,187
1,868
West Midlands
Hymer
Dave Newell fitted mine 7 years ago and no issues at all. If you are in France you need an extra half turn.
Big Nick
Big Nick
260
290
Yorkshire
Newbie
Yeah, Dave explained that the satellite is over the equator so the further south you are in Northern Europe the more you need to crank it up towards vertical.
I was put off the Snipe owing to the extra cost and the failures of the unit I'd heard of whereas with the Camos it seemed to all be positive and many had used theirs without issues for years
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Actually the further South you are in Northern Europe the LESS you need to crank the system up as it is looking directly upwards when parked. Raising the dish actually depresses it towards the horizon.
D.
Big Nick
Big Nick
260
290
Yorkshire
Newbie
Doh!! I knew what I meant!!
Marcus75
43
38
southampton
HYMER b544
new
Hi, is your Camos plugged directly into your Avtex TV or is it running in to a Freesat box first?
Many thanks.
May 12, 2011
1,187
1,868
West Midlands
Hymer
Don't know about @Big Nick but mine goes straight into the Avtex; it has a built in sat. Decoder.
The lead from Camos goes into a finder first, then via an 'L' connector into TV. It means only 1 power lead and channel changing straight on the TV No problem with other satellites, Avtex handles them.
Big Nick
Big Nick
260
290
Yorkshire
Newbie
Many thanks.
I have the same set up at Detnor above.
I find the easiest way to tune it in as 9 turns of elevation, point it east then small rotation towards North and it's the first signal the sat finder starts to whine on. You can then fine tune the elevation until you get the highest whine on the sat finder
I can normally tune it onto Astra 2 in around 2 minutes when in the UK where the signal is strongest but in France it's a tad more difficult and often takes me twice that if away from the north coast
We got UK Freesat as far south as Le Puy En Velay which I thought was excellent for such a small unit
When out of range we tune into Astra 1 to get the news in English but it's mainly German tv on there !!
