Camos Crank-up Sat Dish, Owners Experiences
Discussion in 'TV & Satellite' started by Flamenca, Jun 5, 2015.
  1. Flamenca
    Flamenca Funster Life Member
    Jun 21, 2013
    775
    469
    Cornwall/France/Spain
    I am looking for a budget cost satellite dish and the Camos Crank-up Plus unit seems to fit the bill nicely. However, before I go ahead and buy one I would like to hear from other Funsters regarding their experiences with this particular dish.
  2. chrisboyo
    chrisboyo Funster
    Aug 5, 2009
    1,338
    825
    Newport South Wales
    Good bit of kit
    I had one on the last van and would have one on this van if there was a space to fit it
    Took a little while to get use to it but i could usually set it up in 3-4mins
    If you are in the UK a lot fine, but it was no go in France if you were away from the north coast
    • Like Like x 1
  3. Sheddy
    Sheddy Funster
    Oct 20, 2010
    920
    3,954
    Burry Port South Wales / Benidorm
    As Chris says once you get used to setting it up they are fine, we had the Plus Version with twin LNB and did get all the UK channels May last year down as far as Grenoble in France and our sky channels all over central and northern Italy.
    I would suggest you get a decent signal meter , the buzzer ones can be confusing for adjacent satellites.
    I use one of these. also get a reasonable compass helpful when you pitch up for checking line of sight to the satellite avoiding trees and buildings etc.
    The installation was relatively easy, once you overcome the fear of drilling a hole in the roof :Eeek:
  4. Detnor
    Detnor Funster
    May 12, 2011
    548
    494
    I had one fitted by @dave newell lvs about 5 years ago, still works perfectly. As chrisboyo says, it takes a bit of practice, but you can get it set up quickly. We have had no problems anywhere in France, sitting near La Rochelle at the moment and full tv and radio reception.
    • Like Like x 2
  5. Flamenca
    Jun 21, 2013
    775
    469
    Thanks for the info. Out of interest, which sat box do you have?
  6. Jean-luc
    Jean-luc Funster
    Aug 15, 2014
    104
    69
  7. Detnor
    Detnor Funster
    May 12, 2011
    548
    494
    A cheap comag, got it from maplins, works on mains or 12v. Interesting to read about sat meters, never used one. I put the dish up, put on BBC 2 then adjust until I hear it! Must look at signal meters.
  8. teensvan99
    teensvan99 Funster
    May 17, 2015
    226
    244
    Margate
    Hi.
    We fit the maxview crank up system to our vans. First van was a burstner 748. Had it for 8 years and sold it with system in place working fine. Bought swift escape two years ago and first job fit maxview crank up system. We use the cheap sat box from maplin Fortic star. Work very well in Europe.
    steve & ann. ---------- teensvan
  9. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,091
    1,221
    Dronfield - Derbyshire
    I would also recommend Camos, worked perfectly even down to mid France. Easy to set up once you get used to it and that there are more than one satellite it will try to pick up. There is only one good one.
    • Like Like x 1
