Camos CM-562 rear view reversing camera thing (2 Viewers)
Dave and Ginny
1,569
1,582
Nottingham
Hymer Starline 680
Since 2011, previously a tugger
I'll be honest, don't really like it much when on the road but it does show me the bikes haven't fallen off!
Then when I go to reverse it moves down and now I can't see anything of any use.
Not fitted by me, but would there be a likely easy way to stop it moving from the straight back view to the pointing down totally useless view?
It's on our Hymer B544 and moves when I select reverse...oddly enough (n)
GJH
29,450
38,827
None, now sold
2006 to 2022
The CM-562 is actually the monitor. It appears that it is installed together with a Camos Tilt Camera (similar camera to the one we have on our van) but that the camera isn't set up properly - possibly come loose? The camera should show the road behind during normal driving and then tilt when reverse is selected to show the area just behind the rear of the van.
It would be worth having a look at the position of the camera (two photos of ours attached for reference) and adjust if that is the problem. We are very pleased with ours.
Dave and Ginny
Dave and Ginny
1,569
1,582
Nottingham
Hymer Starline 680
Graham, same camera as yours, it's not come loose and the view behind is correct but when we have the two bikes on the back when I reverse it moves down but the view is obscured by the bikes. If I can stop the 'tilt' action it would be a lot better though.
GJH
29,450
38,827
None, now sold
2006 to 2022
OK, I understand now :) Maybe the solution is to take up walking rather than cycling :)
Dave and Ginny
Dave and Ginny
1,569
1,582
Nottingham
Hymer Starline 680
That makes more sense than you can imagine :)
Reactions: GJH
Dave and Ginny
Dave and Ginny
1,569
1,582
Nottingham
Hymer Starline 680
Not familiar with this camera but certain there will be an input connected to the reversing light circuit if you disconnect it, it should solve your problem.
Cheers Lenny, I'll take a look in the daylight tomorrow :)
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
I have simply placed a dash switch in the reverse sensor cable so that I decide when I wish the downward looking angle, for instance when you have no bike on the back.
Jun 16, 2014
656
2,440
NOTTINGHAM
Autotrail Savannah
Almost a Newbie but not quite now.
Do you not have a button on the dash screen to select which view you require. I replaced the camera on my Autocruise as the monitor was missing on purchase and when I contacted the manufacturers/importers they wanted £580 for a replacement monitor !!!! I purchased a two camera system with enough cable for both cameras and monitor for £50 off fleabay. Fitting a doddle (after exchange of reverse switch on gearbox (peugeot boxer)) and all working as should be.. rear camera just sees handlebars on 2nd bike on Thule towbar carrier,, reversing camera shows carrier and a little of rear,, but bets of all is I can select which camera to view even though the system goes to reversing mode when reverse selected. :)
Dave and Ginny
Dave and Ginny
1,569
1,582
Nottingham
Hymer Starline 680
Do you not have a button on the dash screen to select which view you require. :)
Robert, yes it does have that button, but I sorted it to suit me better today by removing the wire from the reverse lights. At least now it will be of some use when backing up, I'll probably be able to see the wife easier at least!
Cheers for the help on this one...another off the things to do list! (y)
