If it is true that the low pressure is simply a high pressure with a reducer in it ? Then it would be a poor choice to buy a high pressure only to find it fails miserably! At least buy the low pressure so you have an option to remove it
Upstairs for thinking
You do of course have it the wrong way around. The high pressure has the restictor, the low pressure does not. If you have low water pressure the restictor is removed to allow a greater flow. One the other hand when you have high water pressure the restictor stays in ace to avoid too much water flowing through. As I said Ecocamel advised me, I took their advice and it worked fine.Giving thought to
Mine is an electric or low pressure as pictured. If you want to increase pressure due to a low pressure supply you reduce the diameter not increase it
That is the major feature of mixing water with air to create the impression of high volume and thus saving water.Mine works perfectly and undoubtedly saves us water too.
