cambelt swift 590 sl
Discussion in 'Tech/Mech General' started by pinktulip, Mar 14, 2010.
  1. pinktulip
    pinktulip Read Only Funster
    Oct 29, 2009
    8
    Hi, i wonder if any one can advise me
    We bought a Fiat Ducato swift 590 sl S reg it's done 30,000 miles
    Does the cambelt need changing ? If it does can i just change the belt alone ?
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,266
    5,253
    East Sussex 01-580-881288
    I would advise that you do change the cambelt due to age, change the pulleys and tensioner as well, whilst it is apart dont skimp the job.
    Very expensive if it snaps.
    Peter
  3. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Hi cam-belts need changing every 5 yrs or so regardless of mileage (60,000 ish )
    I would change it asap then you know it is OK for another 4 / 5 yrs--- You can just do the belt but the full kit is not much more and IMO is worth doing for peace of mind.
    terry
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    as others have said, if theres no history of a belt change then its advisable to change it.
    its also false economy to change the belt only.....the pulleys will also be worn and could collapse at any time.
    the pulley bearings are pre lubed and sealed so if any seal starts to leak eventually the bearing will run dry and either seize or collapse.
    Geo posted recently one of his customers recently parted with £1300 for repairs after a belt snapped.
    a belt and pulley change may only be 25% of that cost.:thumb:
  5. pinktulip
    Oct 29, 2009
    8
    Cambelt
    Many thanks for your helpfull comments, which we have noted and will do the full job when changing the camebelt .:thumb:
  6. tick59
    tick59 Funster
    Dec 25, 2007
    1,243
    1,089
    Newcastle Upon Tyne
    It is a good idea to do the water pump at the same time.
  7. SpongeBobsDad
    SpongeBobsDad Read Only Funster
    Sep 23, 2008
    107
    4
    north east uk
    Do not rely on mileage I did and it cost me , my cam belt snapped at 35000 miles and 5 yrs old. I thought it was OK , low mileage i thought, big mistake . Caused a massive amount of damage in the end i had to replace the engine at a cost of nearly £3000 . BE WARNED don`t leave things to chance .
