Calor Gas (Propane)
Discussion in 'Motorhome Chat' started by Doddy999, Jun 22, 2010.
  1. Doddy999
    Doddy999 Read Only Funster
    May 3, 2010
    160
    13
    Exeter Devon
    I have two Handy Gas bottles in my van but would like to swop for Calor as more
    easy to get hold of, I also have two blue bottles from calor that I had for the home,
    do any of you guys know if there is any suppliers in South West that would exchange these
    for two Calor?
    Or know of the cheapest way to buy 2 bottles?
    Thanks Doddy
  2. scotjimland
    Jul 25, 2007
    28,940
    25,630
    I'm afraid Calor won't exchange Handy Gas bottles.
    Try your local council amenity site ( tip) or a boot sale for empty Calor bottles.. usually sell for about a tenner
  3. hilldweller
    Dec 5, 2008
    27,567
    26,682
    Macclesfield
    Well if you are about to spend MONEY at least consider Gaslow. Then you have readily available cheap gas all over EU. Use "search+" if you don't know what Gaslow is, it's been done to death many times.
  4. vwalan
    vwalan Funster
    Sep 23, 2008
    7,630
    3,926
    roche cornwall
    hi ,if the two bluebottles you have are calor they will just swap them. try and see every calor place should swap any calor for any calor. you could get an adapter to fill at the garage. off ebay or i can give you a number to ring. cheers alan.
  5. lebesset
    lebesset Read Only Funster
    May 31, 2009
    760
    a friendy calor gas dealer sometimes will swop one type of calor bottle for another , so if you take along the 2 you have unwanted , you might be able to swop for the type you want
    what's wrong with using butane in the motorhome anyway , unless you motorhome in the winter it is actually better
  6. paulmold
    paulmold Read Only Funster
    Jun 15, 2009
    895
    301
    North Wales
    I did the swop from butane to propane, my local calor dealer couldn't have cared less. He says the deposit is the same on all bottles so you should be able to swop any size for a different size and from butane to propane or vice versa.
  7. scotjimland
    Jul 25, 2007
    28,940
    25,630
    The OP can't swap Handy for Calor
  8. lebesset
    May 31, 2009
    760
    2 calor gas bottles that I HAD for the home jim
  9. Doddy999
    May 3, 2010
    160
    13
    Exeter Devon
    Oops English lesson I HAD :BigGrin: yes I still HAVE Jim:thumb:
  10. VMax666
    VMax666 Read Only Funster
    Nov 26, 2009
    172
    Knutsford
    Depends on the place where you exchange. I had a propane bottle with some name on it from Preston, I took a piece of wet and dry to it and removed all traces as it appeared to be only emulsion in a couple of minutes. Dumped it outside the Calor shop in the empty bottle stack, got new calor bottle without a problem:Smile: VMax
  11. lebesset
    May 31, 2009
    760
    doddy , what was wrong with your post ?
    you said you have 2 calor bottles which WERE for your home ...isn't that correct ?
    and what's wrong with them for he motorhome?
  12. Doddy999
    May 3, 2010
    160
    13
    Exeter Devon
    :BigGrin: Ah thought you meant I DID have some, to correct myself I also have two
    Butane bottles that I had for BarbQ which I may, as mentioned by others may be able
    to swop for Propane.
    Thanks to all by the way :thumb:
  13. lebesset
    May 31, 2009
    760
    why do you need propane ?
  14. Doddy999
    May 3, 2010
    160
    13
    Exeter Devon
    Will be up in the Dolomites in Jan or Feb with my ski's, been told it dont freeze.
    and dont like blue:RollEyes:
    Doddy
  15. derekfaeberwick
    derekfaeberwick Read Only Funster
    Dec 1, 2007
    1,131
    8
    Berwick
    If you've got the pigtails- regulators for propane then just chop your bottles in for the 2 biggest propanes that fit your locker.
    Step 2, visit E Bay for adapter to refill said bottles. ( another advantage of propane ).:Cool:
  16. Doddy999
    May 3, 2010
    160
    13
    Exeter Devon
    Calor will allow me to swop bottles to red:BigGrin:
    OK so if I go ahead with getting a valve to be able to refill at garages same as if the vehicle ran on LPG, then just topped the bottles up instead.
    My worry (May be a thick question from a newbie) LPG expands and I would worry about putting 100% in, not allowing for expansion :Eeek: or is this not possible?
    Would I need to get another adapter?
    I'm sure yourself or Alan (VW) will put me right. Sorry again for maybe asking a daft question.
    Doddy :thumb:
  17. scotjimland
    Jul 25, 2007
    28,940
    25,630
    You must never try to 'top up' , the bottle must be empty before attempting to refill ..
    80% is the recommended max and it is possible to overfill if your careless.. which could have dire results.
    For ease of calculation , 1 kg of LPG ( propane) = 2 lt
    so a 6kg bottle holds 12 lt
    The procedure is quite straightforward ..
    a) ensure bottle is empty by venting in a safe area, then close the valve. Best done before arriving at the filling station.
    b) screw on adapter
    c) connect filling gun
    d) open bottle valve
    e) fill bottle to correct amount by watching the LPG pump gauge. This is not critical, you can either stop early or overfill up to 87 % quite safely.
    f) CLOSE THE BOTTLE VALVE ..
    g) disconnect filling gun, pay cashier and walk away smiling.
  18. vwalan
    vwalan Funster
    Sep 23, 2008
    7,630
    3,926
    roche cornwall
    hi doddy .follow jim,s instructions .its easy. use 1 bottle then swap to other .fill empty bottle .best way. if you are down here look me up .may get up your way .usually racing past on way somewhere. think you have my number pm me if you havent . thought i had yours but am losing the plot .have fun ,cheers alan.
  19. Doddy999
    May 3, 2010
    160
    13
    Exeter Devon
    Cheers Alan I'm in Fowey area August but probably couple of long weekends before in Cornwall so we'll pop in. :thumb:
  20. Terry
    Terry Funster
    Dec 27, 2007
    10,771
    6,291
    South yorks
    Hi doddy the only other thing I can add to Jim's post is it helps if the bottle is secured in position as this makes it easier to fasten the lpg gun onto the filler :thumb: but not essential - I usually leave the valve open once I fit the adapter onto the bottle ready to accept lpg straight away :thumb: you will only forget to close the valve after filling once :Rofl1:
    terry
