Calor gas, how does it work? (1 Viewer)
TheDeckKing
137
114
Hyde, Cheshire
Talbot Voyager 2 coachbui
Newbie
Picking up the new (to us) motorhome on Sunday. Saying we're excited is a huge understatement. Just realised that I've never dealt with gas cylinders before. The MoHo comes with a calor cylinder. Can I just take this to my nearest stockist for a refill when it runs out or do I need the original paperwork?
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
no problem as long as you have one the same, calor flogas etc .if it's calor, believe it or not but you'll find go outdoors is cheapest
TheDeckKing
TheDeckKing
137
114
Hyde, Cheshire
Newbie
Thanks. Sounds easy enough. We've got a Morrisons nearby that sell them or can go a little further afield to go outdoors too
PP Bear
7,806
28,776
Kent, UK
Auto Trail Dakota SE
Good luck with the new motorhome, we've all had that "can't sleep with excitement" feeling while the clock ticks by slowly to the pickup date/time :)
homercostello
232
209
kidsgrove staffs
Dethleffs globetrotter
9 years
Make sure you have propane rather than butane thats the red bottle for propane and blue for butane propane is better as it freezes at a lower temp
and can be used in the winter.
eddie
8,157
41,266
Taunton Somerset
RV
since 1989
Or you can get cylinders that you top up sat the garage, instead of taking out!
eddie
8,157
41,266
Taunton Somerset
RV
since 1989
There are other systems than Gaslow.
As for making economic sense? it doesn't always, but for convenience especially if your touring around Europe where each Country has it's own bottle and regulator configuration.
Also if your less able bodied, filling at a pump is easier than lugging bottles around.
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
I think the OP might be shocked enough at paying over £20 for a 6kg Calor bottle, let alone considering several £100's more on one of the refillable options :D
DuxDeluxe
14,658
72,771
Planet Zog
A woosh bang van
since 2008
Yep, three options:
Exchange existing calor gas bottles like for like when empty. Costs the price of the gas £25 for 13kg +/-
Buy a refillable system such as Gaslow and Gasit etc and refill from LPG pumps at fuel stations. Costs £200-400 for the system but gas is about £0.75 +/- per litre. Economics depends mostly on convenience and amount of use.
Fit an underslung refillable LPG tank and refill as above. Costs £500+ If there is room underneath but frees up gas locker space and cheap LPG as above.
Horses for courses, but whatever you do, don't buy an adaptor of eBay and try to refill your calor cylinders (as some clown on the motorhome FB page recommended) as this is dangerous and contravenes health and safety regulations. Designed refillables have a safety shut off to prevent filling over 80%. The 20% ullage space above is essential for safety, effective vapour supply and expansion of the gas liquids.
Petrol station LPG is mostly propane throughout Europe and can be used at lower temperatures than butane
TheDeckKing
TheDeckKing
137
114
Hyde, Cheshire
Newbie
Thanks for all the advice. Think I'll stick with the calor refills to begin with and see how much we use. It's a case of how long is a piece of string at the moment.
13,083
101,448
Hymer S800
not long enough
If you only have one bottle, keep an eye out for another, they are really hard to predict when they will empty, even with a gauge, the only sure thing is heavy rain or overnight are the most likely times to run out
if you don't have a spare bottle you will inevitably waste gas when you swap before you have run out (y)
TheBig1
17,630
43,272
Calor and other exchange cylinders are a real pain. you run out of gas at the worst possible time then have to find a local stockist where you are. or you check the contents before leaving on holiday and end up giving an unknown amount of gas back when you get a replacement. very expensive long term
fit a refillable kit and you can top up at many petrol stations before you run out. plus it just unscrews from the van to move to your next van when you upgrade. works out cheaper long term, plus the gas is so much easier to get and no heaving heavy cylinders in and out of lockers etc so safer
TheDeckKing
TheDeckKing
137
114
Hyde, Cheshire
Newbie
Depending on how much we spend getting the MoHo up to scratch there may be some money left for the upgrade, but not much. What's the cheapest way to get a refillable setup with buying a dodgy adapter off eBay?
DuxDeluxe
14,658
72,771
Planet Zog
A woosh bang van
since 2008
Try looking at Hamilton gas products. I would be wary of buying used unless you are sure of the age and condition. Other sellers are available of course but they do seem to be the cheapest around
Hamilton Gas Products Ltd
www.gasproducts.co.uk/
Hamilton Gas Products Ltd - Buy discount Gas Fittings, Gas Regulators, Flue Gas Analysers and Plumbing Supplies online. 5000+ Products for the gas installer ...
13,083
101,448
Hymer S800
not long enough
Don't be bullied into it, there are probably far more on here with standard Calor bottles than refillable systems
Those that have them tend to be the loudest advocates :D
Get the MH, use it and enjoy it (y)
Emmit
8,034
17,753
Cornwall
Pilote Explorateur
Jan.2014
Assuming you are given a calor Propane bottle (and if they try to give you a butane bottle, kick off), give these people a ring, or order on line.
They will supply a Flogas Propane bottle to your door for a fraction of the Calor price.
You will then have a bottle from each of the two UK suppliers and you will be able to choose which one gives the best deals (and I already know which one it is;))
http://www.alfrescoproducts.co.uk/online-shop/
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
if going abroad local bottles can be cheaper than auto gas pumps .
many places abroad will fill uk bottles if you want .
i find flo gas is cheaper any way. secret is a big gas locker then you can carry two 19kg bottles . or a spanish bottle and a Moroccan one depending where i,m going . only about 6 quid difference between exchange or filling at the auto gas pump.
scotjimland
2,324
10,054
A Woosh bang
Agreed..
Bottle gas is available EVERYWHERE .. from the most Northerly far flung Scottish Isle, to the deserts of Morocco..
You can't always find a garage with LPG ..in some places like Spain they are a bit thin on the ground, although the network is expanding.
The most flexible system is one refillable bottle and a space for a pre-filled bottle.. that way you can benefit from lower cost LPG when it's available, and when it's not, buy the local bottle , no matter where you are.
Tanks are good as they free up a locker, and if you fit a BBQ point you can use that to feed in gas from a locally bought bottle .. which of course you can also do with the Gaslow system..
Whatever you do.. don't rush in to buy stuff just because its sounds like a good idea.. same goes for solar panels etc.. Find out what YOU need.. not what others tell you you need.
DuxDeluxe
14,658
72,771
Planet Zog
A woosh bang van
since 2008
Good advice, Jim.
I'd love another Gaslow system but can't really justify it at the moment
11,726
13,705
Since 2013
Do as I did and get a single 11kg refillable bottle from a company called Gasit. They use exactly the same bottles as Gaslow except that they are a different colour and sell direct, which makes them a lot cheaper than Gaslow. I got the bottle plus filler system for locker and 3 adapters for use in Europe for about £190. Delivered the next day and took me a couple of hours to fit at most. And I keep the calor bootle I have in the locker in case I ever run out of gas from the Gasit, but I never have yet.
DuxDeluxe
14,658
72,771
Planet Zog
A woosh bang van
since 2008
Yes, priced it all up and Hamilton are cheaper for a Gaslow system and do free delivery
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Just as an aside, be aware that the regulator thread is LEFT HANDED ie. to undo it you unscrew it (you will need a small dedicated spanner, ask dealer to supply) CLOCKWISE and not anticlockwise as you might expect.
Cheers, Dave(y)
312
287
Holmfirth
1990 Gulfstream RV
30yrs
The simple answer to this thread is stick with calor gas bottles, but as said, there are many other ways, and the ebay thingy mentioned works fine, as long as you use two bottles, and only fill a properly emptied one to 80% capacity. If you dont fully understand this, then stick with calor bottles, which can be found most anywhere....for a price.
