Cadac lid required (1 Viewer)
Mousy
3,485
20,318
Sa15 2DG
Hymer S840 Merc auto
Since 2013
Hi, anyone know where I can get a lid for a cadac carri chef BBQ?
Cheers mousy
Mousy
Mousy
3,485
20,318
Sa15 2DG
Since 2013
Brilliant thanks, didn't realise they were so expensive!
Extra strong tin foil at the ready..:thumb:
Mousy
Mousy
3,485
20,318
Sa15 2DG
Since 2013
Only problem with a wok lid is I can't use it hooked on the side as a windbreaker.
Scattycat
920
1,262
Mayenne, France
Rapido
Since 2010
So, what happened to the original lid?
Have you tried getting in touch with Cadac to see if they can supply one?
We had a problem with the surface peeling off the flat tray. Sent an e-mail to them with a photo showing the problem and supplied a replacement F.O.C. within a few days
Mousy
Mousy
3,485
20,318
Sa15 2DG
Since 2013
Well I could spin a few tales...
Sons used it for sledging.
Grandma turned it into a bird bath.
I drove over it by accident.
But really....
We bought a cadac carri chef but it was lidless. :Sad:
43,289
49,223
you can by buying a flat plate coat hook and rivetting to the lid......cut off the long bit above the two holes....you can easily work out where to drill and rivet.
Effectively, its exactly the same as the proper thing.
Mousy
Mousy
3,485
20,318
Sa15 2DG
Since 2013
:ROFLMAO: me RIVET ! :ROFLMAO: you massively overestimate my skill set :ROFLMAO:
Thanks for the laugh papajohn and the ideal, if only...
43,289
49,223
in a word....No. :roflmto:
Open the handles, push a rivet in the end of the short tube, push the exposed end of the rivet through the drilled hole in the metal and squeeze the handles together...job done.
Broken Link Removed
Mousy
Mousy
3,485
20,318
Sa15 2DG
Since 2013
Thank you, that does look doable, not what I was thinking of at all! :thumb:
Minxy
32,621
66,436
E Yorks
Carthago Compactline
If the wok lid has a wooden handle (most have) then drill a hole and screw in a large cup hook ... ::bigsmile:
Jaws
23,827
72,281
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Would you believe I do have a brand new spare lid
Bought it for someone and they then changed their minds !
Mousy
Mousy
3,485
20,318
Sa15 2DG
Since 2013
Would you like it to go to a good home? Full of mouses? ::bigsmile:
Jaws
23,827
72,281
Thetford Norfolk
C class, Chieftain
Are you going to Peterborough show ?
I expect I could be talked in to swapping it for a glass of scotch and coke or similar ::bigsmile:
Mousy
Mousy
3,485
20,318
Sa15 2DG
Since 2013
Sadly not, we are going to Chester food festival though are you? And scotch as a currency is an inspired ideal. I normally deal in homemade cakes! ::bigsmile:
Jaws
23,827
72,281
Thetford Norfolk
C class, Chieftain
No mate, but perhaps someone who is going to Peterborough is also going to Chester ?
Mousy
Mousy
3,485
20,318
Sa15 2DG
Since 2013
I'll check later but I think Chester is before. I'm sure we can work something out. Cheers jaws. :thumb:
Jaws
23,827
72,281
Thetford Norfolk
C class, Chieftain
If you PM me at the end of March I will check on shipping costs for you mate.. Should not be too much so might be the way to go :thumb:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Me but Chester comes first so I'll have the glass of scotch and pass it on
