Cadac lid required
Discussion in 'Motorhome Chat' started by Mousy, Feb 17, 2014.
  1. Mousy
    Mousy Funster Life Member
    Sep 13, 2013
    2,301
    8,134
    Sa15 2DG
    Hi, anyone know where I can get a lid for a cadac carri chef BBQ?
    Cheers mousy
  2. Armytwowheels
    Armytwowheels Funster Life Member
    Aug 10, 2012
    4,282
    6,966
    Spain for the winter
  3. Mousy
    Sep 13, 2013
    2,301
    8,134
    Sa15 2DG
    Brilliant thanks, didn't realise they were so expensive!
    Extra strong tin foil at the ready..:thumb:
    • Like it Like it x 1
  4. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,017
    5,377
    Wirral
  5. Mousy
    Sep 13, 2013
    2,301
    8,134
    Sa15 2DG
    Bigfoot you are an inspirational genius :BigGrin::thumb:
  6. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,017
    5,377
    Wirral
    I try!
  7. Mousy
    Sep 13, 2013
    2,301
    8,134
    Sa15 2DG
    Only problem with a wok lid is I can't use it hooked on the side as a windbreaker.
  8. Scattycat
    Scattycat Funster
    Jan 3, 2013
    846
    1,186
    Mayenne, France
    So, what happened to the original lid?
    Have you tried getting in touch with Cadac to see if they can supply one?
    We had a problem with the surface peeling off the flat tray. Sent an e-mail to them with a photo showing the problem and supplied a replacement F.O.C. within a few days
  9. Mousy
    Sep 13, 2013
    2,301
    8,134
    Sa15 2DG
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,385
    18,074
    YO11 2BD
    you can by buying a flat plate coat hook and rivetting to the lid......cut off the long bit above the two holes....you can easily work out where to drill and rivet.
    Effectively, its exactly the same as the proper thing.
    [​IMG]
  11. Mousy
    Sep 13, 2013
    2,301
    8,134
    Sa15 2DG
    :Rofl1: me RIVET ! :Rofl1: you massively overestimate my skill set :Rofl1:
    Thanks for the laugh papajohn and the ideal, if only...
  12. pappajohn
    Aug 26, 2007
    30,385
    18,074
    YO11 2BD
    could get someone to do it for you....only takes a few mnutes once its marked out.
  13. Mousy
    Sep 13, 2013
    2,301
    8,134
    Sa15 2DG
    Is it like a staple gun?
  14. pappajohn
    Aug 26, 2007
    30,385
    18,074
    YO11 2BD
    in a word....No. :Laughing:
    Open the handles, push a rivet in the end of the short tube, push the exposed end of the rivet through the drilled hole in the metal and squeeze the handles together...job done.
    [​IMG]
  15. Mousy
    Sep 13, 2013
    2,301
    8,134
    Sa15 2DG
    Thank you, that does look doable, not what I was thinking of at all! :thumb:
  16. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    10,845
    12,162
    E Yorks
    If the wok lid has a wooden handle (most have) then drill a hole and screw in a large cup hook ... :BigGrin:
  17. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,958
    23,796
    Narrfoook
    Would you believe I do have a brand new spare lid
    Bought it for someone and they then changed their minds !
  18. Mousy
    Sep 13, 2013
    2,301
    8,134
    Sa15 2DG
    Would you like it to go to a good home? Full of mouses? :BigGrin:
  19. Jaws
    Sep 26, 2008
    18,958
    23,796
    Narrfoook
    Are you going to Peterborough show ?
    I expect I could be talked in to swapping it for a glass of scotch and coke or similar :BigGrin:
  20. Mousy
    Sep 13, 2013
    2,301
    8,134
    Sa15 2DG
    Sadly not, we are going to Chester food festival though are you? And scotch as a currency is an inspired ideal. I normally deal in homemade cakes! :BigGrin:
