Cadac BBQ and gas pipe help please
Discussion in 'Motorhome Chat' started by Hudders1, Apr 23, 2014.
  1. Hudders1
    Hudders1 Read Only Funster
    Sep 14, 2013
    184
    65
    Huddersfield
    Hi I have just got a cadac BBQ and I'm wanting to connect it to my gas cylinder in my motorhome the cylinder is in a side compartment. How far can I have a pipe from the regulator and can I use a t junction and quick release nozzle and jubilee clip? I have tried looking but cannot get much info regarding connecting etc. thanks
  2. Inthezone
    Inthezone Read Only Funster
    Feb 14, 2014
    146
    105
    Berkshire
    BBQ Point
    I would suggest that you fit or have fitted a proper exterior BBQ point, dont scrimp on somthing that has serious saftey implications,
    Also its much easier in the long run to have a proper exterior point fitted, there available at most caravan / motorhome shops.
    I am sure that the cost of fitting will be reasonable, and at least you will be able to rest knowing that its safe.
    Hope this helps:Smile:
    • Like Like x 1
  3. New Dawn
    New Dawn Funster
    Oct 24, 2013
    422
    268
    Nantwich. Cheshire
    You can contact Cadac direct. Can't find the number, but check on website, they will have all the info you need. Exterior fitting for gas outlet is the way we went. Sorry can't be more helpfull.:thumb::thumb::thumb:
  4. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,844
    1,902
    Warwickshire
    I suggest you fit one of these - Funster discount available from John Cross.
    http://www.johnscross.co.uk/products/bullfinch-gas-point.html
    Or have one fitted - there must be a Funster fitter somewhere near you.
    There is a similar item manufactured by Reich but I prefer the Bullfinch as it has an auto shut-off valve that operates as you insert or remove the coupling.
  5. Clive
    Clive Funster Life Member
    Apr 30, 2012
    768
    1,183
    Canvey Island
    I had one of these fitted for £75, seems silly to muck about :Eeek:
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,883
    17,542
    YO11 2BD
    Always use a hose designed for use with LPG. The hose should have a maximum length of 2m with clamps at both ends.
    any responsible seller will only sell in 2mtr lengths....i found this out at my local farmers/country store.
    Nothing to stop you buying any length from ebay or at the various mh shows.
    They arent concerned with your safety....only in turning a quid.
    I bought 2 x 2mtr lengths and a suitabl sized barbed coupler to join them together.
    As already said, by far the quickest and safest method of connection is a dedicated external BBQ point.
