Cab 12v wiring for fiat cheyenne 696g 3.0 160 multijet
Discussion in 'Motorhome Chat' started by jetsets, Jun 26, 2013.
  1. jetsets
    jetsets Read Only Funster
    Jan 26, 2012
    10
    derby
    Hi anyone got any info on where I can find some 12v ( always on) and ignition switched 12v and if poss the speed signal for my 2008 Cheyenne SE. its a 2008 Fiat 3.0 160 Multijet
    I have my old VDO sat nav ready to go in but don't want to start too much poking in the wiring, I am competent at wiring and understand electronics/electrics, but if anyone has some tips it would save me some time.
    When I took it out of the old van it looked a bit of a bodge into the existing looms behind the glove box and dash.
  2. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    have you had a look here?
    http://www.sargentltd.co.uk/Autotrail_schematics_2007.pdf
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,900
    17,563
    YO11 2BD
    switched and unswitched supplies should be easy enough to trace in the ign switch harness multi plug or there may even be a couple couple of spare ways in the fuse box
  4. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Need age and type of van if you can, then I can give you the info. The power supply depends on what type of van it is, as some newer ones need to be isolated.
    Scratch that - must read properly! PM Sent.
  5. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,115
    3,518
    walthamstow east london
    x250s run canbus systems permenant live can be direct from battery but im not sure how you would get a ignition feed maybe rainbow can tell me as well
  6. jetsets
    Jan 26, 2012
    10
    derby
    found something behind radio
    Hi Thanks for messages and replies, found switched and perm live behind radio, in fact radio does not run off the normal (yellow) perm live so can use that. wire already cut for me to connect to.
    Found a switched live also there ( Red). also had a pm saying where to look for speed wire so looking good so far. Just the rain now making it a pain to work on - opening closing doors in and out getting tools connecters etc.
    many thanks all
