buzzer
Discussion in 'Motorhome Chat' started by mark91068, May 11, 2009.
  1. mark91068
    mark91068 Read Only Funster
    May 5, 2009
    13
    Tamworth
    Help I have a buzzer in my glove box (Ford Transit Herald Aragon) it come on about a week ago intermiten but yesterday it came on for ages I have checked all the usual oil water ect I followed the wire there is a relay and feses with heavy red wire it ony works with the ignition on and its not ford wiring MARK
  2. davetthedon
    davetthedon Read Only Funster
    Mar 25, 2009
    141
    Malvern, Worcestershire
    Buzzer?
    Is it for your step? I have a cut out switch in the glove box to stop someone retracting the step whilst stationary on site, and also there is a buzzer behind the glove box which tells you when the step is out if you turn on the ignition, this is a little intermittent as the switch sometimes sticks closed.
    ATB
    DaveT
  3. philw111
    philw111 Funster
    Mar 22, 2009
    606
    518
    Moray Firth
    Hi Mark
    Our motorhome was fitted with a buzzer to tell you that the step was still out. Not long after we got it, this started coming on intermittently while driving. I eventually disconnected it from the step and removed the buzzer unit as everything I tried to fix it failed.
    May not be the same problem but it's worth checking...
    Phil
  4. mark91068
    May 5, 2009
    13
    Tamworth
    I dont have an electric step but I will look mfor a sensor on it thanks
  5. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,827
    9,038
    Tropical Bar,Benidorm.
    Hi Mark
    We don't have an electric step either, but there is a micro switch fitted to warn you if you drive away with the step in the out position. I suspect that the switch may be dirty, a good clean of the micro switch with WD40 may solve the problem.
  6. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,174
    14,066
    Heavan
    also mark, if you have any external lockers, check them as well. We used to have a buzzer fitted to an external locker so you dont drive off with it open, however, it was always playing up. I disconected it in the end:Wink:
  7. mark91068
    May 5, 2009
    13
    Tamworth
    this is so cool thanks ....I would never i thought of any of that I will let you all no
  8. mark91068
    May 5, 2009
    13
    Tamworth
    buzzed off
    :thumb: just a thank you to all that helped the dodgy step sensor was the problem :Wink:
  9. davetthedon
    Mar 25, 2009
    141
    Don't you just love it when a plan comes together!:thumb:
