Butane Regulator on Propane? (1 Viewer)
weejocky
Jan 20, 2010
162
457
Yorkshire and France
Hymer A Class
not long enough
I am going to change to Propane so that it works better in this very cold weather. Never used propane before. Is my existing Butane regulator OK or do I need to change it?
meanders
Funster - Life Member
2,599
8,417
Ipswich, Suffolk
C class
Since 2004
You will have to change the regulator as the pressure in the cylinders for propane & butane are different
oldun
747
162
St Neots
VW Campervan
Since 2001
Not if you have the current system with a bulkhead mounted regulator. In this case all you will need to change is the pigtail (pressure hose from bottle to bulkhead regulator)
oldun
747
162
St Neots
VW Campervan
Since 2001
Duplicate post please remove.
