Butane And Propane
Discussion in 'Motorhome Chat' started by gazzeroo, May 29, 2015.
  1. gazzeroo
    gazzeroo Funster
    Sep 14, 2014
    63
    5
    Norwich
    Could someone offer advise please, I have 2 bottles of 6kg propane in my MH and would like to have 1 propane and 1 butane ( because as I understand it Butane burns hotter, therefore heats quicker). Would it be safe to to have one bottle of each on a tee, obviously with the appropriate regulators, or would the slight mixing of the gases when I change over bottles be a problem. I always I really appreciate your answers
    regards
    Gary
  2. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,751
    11,954
    Plympton, Devon
    Don't bother, there is a negligible difference in flame temperature - a few degrees and though butane has more energy per kilogram you won't notice any difference and if it is a bit chilly then propane will aways out perform butane.
    • Like Like x 1
  3. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,016
    6,039
    West Sussex
    Stick with propane, the only time you might want the extra heat the butane won't work anyway, in practice you won't notice the difference.
    Butane stops gassing off at 0 deg, but pressure gets to low to be any use way above that, in practice you start to notice at about 6-7 deg that nothing is working properly.
    Propane stops gassing at -40 deg.
  4. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,863
    roche cornwall
    doing what you said you wont notice the difference with mixing the gas . actually butane regulators and propane regulators overlap in the pressure bits .
    but as said you are probably better off sticking with propane .
    mind when i,m in spain or morocco i use butane . just because it was cheap and easier to get .
    if i should go anywhere really cold i can swap to the uk propane .
    over the years have had propane put in butane bottles , butane in propane bottles didnt really cause a problem . when in some countries you just have to have what ever gas they can get in your bottle .
    • Like Like x 1
  5. gazzeroo
    gazzeroo Funster
    Sep 14, 2014
    63
    5
    Norwich
    Thank you all for that, I wont bother with that then||
