Burstner Travel Van Gas Heater (1 Viewer)
Greenacres
82
13
Stoke on Trent
Burstner Travel Van t620
13 years since retirement and many younger years as a Hippy in a VW conversion, roaming the Greek Is
Hello. The dial on the Truma is set for winter, which means the heater will work without water in the boiler.
It kick in, green light on. It picks up speed then the orange light comes on and everything cuts out. Any advice welcome. It worked fine last time it was required. Thanks
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Not an expert on Truma heaters, but the 'winter' setting on a Webasto is to heat water AND air.
Have you got it the right way round? There may have been water left in the boiler the last time you used it. The water might be gone now because the frost valve dumped it.
Greenacres
Greenacres
82
13
Stoke on Trent
I've just re read the manual and the single flame without the wiggley
water symbol is the inter setting.
SandraL
1,373
985
Somerset
Hymer b694sl
On that flame without wiggly setting heater will heat up the air. The water will also get warm but temp of water will not be monitored. If the gas is low pressure or fails you will get a red lamp. If the air stat setting is on Max the fan will blow lots assuming van is cold. If van is warmish and air stat is only just calling for heat fan will be slow and for us inaudible. This on gas only truma 6 circa 2012.
According to our truma instructions in that setting the yellow lamp only comes on if water temp below 5deg C.
Greenacres
Greenacres
82
13
Stoke on Trent
Thankyou but I think it was an air lock, as it seems to be ok now
