Burstner T615 Not Charging Leisure Battery In Ehu
Discussion in 'Motorhome Chat' started by donnkim, Jun 22, 2015.
  1. donnkim
    donnkim Funster
    Jul 29, 2012
    107
    50
    Bury
    Can anybody suggest a solution as I find it hard to get local Caravan/Motorhome service guys out to see me. Must all be really busy.
    An indicator light on the control panel used to light up when on EHU. This has not lit up and the leisure battery is not being charged. When I run the engine you can see the leisure battery is charging.
    Do you think it is a problem with the large Elektroblock? And is it something I can sort?
    thanks
    Don
  2. elamessa
    elamessa Funster
    May 20, 2009
    508
    480
    Haute Vienne, France
    Are the 240v sockets working and have you checked the trip switch which will be located near to where the ecu cable plugs in, sometimes at the back of a wardrobe.
  3. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    Do you have a Schaudt Over Voltage Protection unit fitted?
    We had a similar problem on our t625 earlier this year, just before we went to Peterborough Show. I'd put the van on hook-up to cool the fridge down the previous day and all was well. Went in the morning we were going away and the 230v light was out but the RCD that the lead was plugged into hadn't tripped.
    As the battery was fully charged, and the 12v system worked OK, I wasn't immediately concerned as I knew we would not be on hook-up during our trip.
    When we got back I checked the 230v sockets and they worked OK so looked in the handbook to see that it says that the lamp comes on whenever line voltage is available at the transformer/rectifier unit. That prompted me to look at the Elektroblock and the OVP and I found that the OVP plug had come loose somehow. All I had to do was to push it back in properly and everything was fine.
    I hope this (or something equally simple) is what caused your problem.
  4. donnkim
    donnkim Funster
    Jul 29, 2012
    107
    50
    Bury
    yes all 230v sockets are working
    how do I identify the OVP Plug?
  5. GJH
    Aug 20, 2007
    27,349
    34,968
    Our Elektroblock is fitted under the driver seat. The photo shows it with the OVP (blue box) in front. The white lead at the right plugged into the OVP is the original 230v power lead. The lead next to it goes to the Elektroblock at the top where the white lead was originally plugged in.
    If you don't have an OVP then the equivalent of the white lead should be plugged into the Elektroblock.
    Whatever set-up you have, check that all leads are securely plugged in. ovp.jpg
  6. s20hymer
    s20hymer Funster
    Jun 11, 2011
    274
    331
    Wiltshire
    hya ovp should have two lights lit if working o/k
  7. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,614
    3,440
    Telford, Shropshire
    My money says your Elektroblok charging unit has failed. The 230V lamp on control panel is fed from the 12v output of the Elektroblok charger. EBLs do not like voltage fluctuations which is why Schaudt developed the OVP unit to protect them. Remove EBL, send it to Schaudt in Germany and they will fix it and send it back. Cost was about £200-£250 last time we sent one out and turn around time is generally about 2-3 weeks.
    When you get your EBL back fit an OVP to prevent it happening again.
    D.
  8. s20hymer
    s20hymer Funster
    Jun 11, 2011
    274
    331
    Wiltshire
    hya i dont know how practical you are or how soon you need your van...but there is firm called A and M Caravans find on google i think in wales...they have all elektrobloks in stock new and reconditioned they are very helpfull there blurb on ebl s is worth reading and other charging units hope this helps
  9. s20hymer
    s20hymer Funster
    Jun 11, 2011
    274
    331
    Wiltshire
    sorry i meant A and N caravans the keys next to each other
  10. donnkim
    donnkim Funster
    Jul 29, 2012
    107
    50
    Bury
    Thanks everyone. got sorted at A & N Caravans near Conwy. Allen was so helpful and really knowledgeable. Can't fault him or the service.
    An exchange remanufactured unit £270 all done in an hour.
    He also restores old Citroen Vans - brilliant!!
    • Like it Like it x 1
  11. s20hymer
    s20hymer Funster
    Jun 11, 2011
    274
    331
    Wiltshire
    hya glad Allen fixed you up i have had nothing but good reports about them...makes a change these days ...
