Burstner Seats - armrests (1 Viewer)
Jan 19, 2013
132
109
Worcestershire
since 2010
Hi, I have a 2003 Burstner 660 and we are getting all the seats re-upholstered this month in leather.
However, I have a small problem. I thought that before the seats were collected i'd tackle the arm rests & improve them as they were all different degrees of 'stiff .... to .... floppy' (no puns please ::bigsmile: )
However, that does not seem easily done .... as the arm rests are held in place by a nut through which a cotter pin holds the nut in place, this is designed to prevent the nut coming loose through the normal arm rest up & down motion.
Playing with the adjustment of this nut, I achieve an arm rest that is really tight or an arm rest thats is loose ?
Unfortunately, I cannot remove the arm rest ..... it appears that the mechanism must be released from inside the back of the seat & the nut on the outside is for adjustment only ? :wub: I presume that when the seat is re-upholstered this will give access to the arm rest fixing & they can be removed.
My problem is; I think the arm rest internal mechanisms have worn with age and that the 'floppyness' of the arm rest is due to worn parts. (there are steel bars that run through nylon spacers / sockets ... & they look worn / mis-shapen )
I am worried that the seats after re-upholstering will be let down by the 'worn' arm rests & i'll be disappointed with the outcome. ( the arm rests will only get worse over the next 5 - 10 years !)
So, my options are ......
1.) investigate whether it is possible to get new arm rest mechanisms ? & fit before re-upholstered
2.) dispense with the arm rests & re-upholster seat without arm rests
3.) buy new seats ?
1.) unlikely to find ? could be expensive .... possibly could get 2nd hand ?
2.) zero cost ...... no delays
3.) EXPENSIVE ?
I am tending towards Option 2. ...... Any other ideas anyone ? :think:
Aug 6, 2013
11,941
16,534
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
If you remove the pinned nut presumably the adjuster is engaged in a part of the bar and prevents the rest being removed? It's unlikely that it is held from within the seat back. Is there a slot or other access into the arm from its upper surface? Until you remove the armrest you won't know what is worn or damaged. I'd be unhappy to lose mine.
Jan 8, 2013
8,478
11,516
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I seem to remember an allen key screw in the arm pivot that came adrift in my T660, as I remember you have to push the upholstery on the sides back?
I would not dispense with arms they make the seat into a proper comfortable 'arm' chair
cornish boy
892
2,365
Body in Hampshire, heart in Cornwall
Swift Kon Tiki 669.
not so newbie anymore - since 2016
If you fold the backs of the seats down onto the base as far as possible and look at the bottom edge I expect you will find the zip or hand stitched seam that closes the seat back upholstery and provides access to any internals on the arm rests.
43,207
48,830
just to be pedantic......thats a roll pin, and you need a very close fitting drift to remove it or it will spread open and peen over making it almost impossible to remove.
a cotter pin is tapered with a securing/tightening nut, as in a bicycle pedal.
Lenny HB
52,709
147,674
On the coast in West Sussex
Hymer B678 DL
They look like Fiat seats as you look like you plan to keep the van for a few years I would bite the bullet and buy some decent seats like Aguti seats, you won't regret it.
iceclimber
Jan 19, 2013
132
109
Worcestershire
since 2010
thanks, but ...... they are actually Aguti Liner seats (dated 2002)
I'll contact TEK seating on Tuesday to see what they can suggest / offer ?
iceclimber
Jan 19, 2013
132
109
Worcestershire
since 2010
yep thanks, I couldn't remember the name of the 'pin' & you are correct about removing them !! ..... I was ok on 3 of the threads BUT buggered up 1 of the threads :cry:
iceclimber
Jan 19, 2013
132
109
Worcestershire
since 2010
thanks .... I removed seat base and folded seat fully to get access to the bottom of the back & no zip / no seam BUT there is a plastic clip arrangement across the full length; lots of pressure on it (as to be expected) for which I am sure there is a correct technique for parting the clip .... I had a dabble at it but I don't want to ruin the clip by bending it or something similar ?
Nov 7, 2015
496
466
Newport, Shropshire
Autosleeper Broadway
since 2015 previously caravaning 25 years
Have you tried using a shim washer or two under the nut ?
Say about 10 thou thick
Lenny HB
52,709
147,674
Hymer B678 DL
Sorry for the insult didn't look like them to me. Worth contacting Aguti see what they say.
iceclimber
Jan 19, 2013
132
109
Worcestershire
since 2010
So, I contacted Aguti through the UK distributers & guess what .... after 7 weeks ...... No reply :cautious:
So the seats have now been re-upholstered without the arm rests ..... & they do look really good & sleek. (the armrests can always be retrofitted in the future if so ever needed)
I will post re-upholstery results separately in the appropriate section. (y)
