Burstner Owners (1 Viewer)
Apr 25, 2016
583
1,913
Soham, Cambs
Consort Oslo
Since 2016
the fresh water tank in our Burstner, has a very small leak around the large red inspection cap, which is on the side of the water tank.
There is a foam washer/seal that doesn't seem to want to seal it. It releases a small bead of water which can then drop down onto the van floor.
Have taken the red cap off and re-seated the foam seal and replaced several times, but with no joy. The dealer did put a new seal in, which did work initially, but then after a couple of days, the inevitable drip re-appeared.
Firstly, is there a better type of seal to use rather than a foam one? If so has anyone tried one?
Where can I get spare seals from. Looked on the South Downs on-line shop site, but don't see one listed.
This is not a major problem, but just one of those simple but annoying issues that just can drive you round the bend!
Anyone else experienced the same problem?
GJH
29,450
38,828
None, now sold
2006 to 2022
Our tank (2003 t625 Harmony) has the inspection cap on the top so less chance of a problem for a start I suppose. I've just checked and it is a male cap (screws into, rather than onto, the tank) with a rubber seal. I'm surprised yours isn't a rubber seal.
Camper UK list a couple of seals Here.
1,302
736
Norwich
Carthago A class
Since 2014
Nigel, we have the same problem with a similar model Burstner. It will have the same tank as yours. We have the same leak and put a rolled up microfibre cloth underneath the tank. We have just had the seal replaced but think it still leaks a little. Have a look at the seating surfaces on the red "plug" and also the tank. I haven't fully resolved the problem yet as I hoped a new seal would sort it but seems it doesn't. I often travel with the tank level below this point. The majority of the tank capacity is below this point anyway (notice how long it takes to fill the first few inches, then no time at all for the last 8 to 10 inches).
As a point of interest have you used you grill for any length of time? we had no end of trouble keeping it lit for longer than 5 minutes!
Nigel L
Apr 25, 2016
583
1,913
Soham, Cambs
Consort Oslo
Since 2016
Thanks GJH, that looks exactly like the one fitted in ours. Yes, ours is a foam seal, and I think what is happening is that as you tighten the cap, the foam twists and so dosen't form a tight seal. I think that a rubber one would be much better and durable. Will order one and give it a try.
As you can see, a good old bit of trusty gaffer tape positioned to divert any drips to outside the van, as opposed to dropping into the floor area:)
Nigel L
Apr 25, 2016
583
1,913
Soham, Cambs
Consort Oslo
Since 2016
SteveC, oh yes, the grill bar fell off ours when we picked the new van up from the dealers. They took another oven out a another new van and put in ours to get us on our way, and guess what, that one didn't work either!!
We are now awaiting a new oven from Dometic. Have to say the dealers have been really helpful over it. (Heart of England).
Looks like there is an issue with the ovens.
1,302
736
Norwich
Carthago A class
Since 2014
Dometic know about the problem. We had a Dometic engineer out to look at ours and he said they have issued a fix which is just a bodge really. Our burner bar eventually fell out recently too. Sorted by Southdowns on our recent trip down there. Been back a day and now a spring in the toilet door handle has broken so the door doesn't close! The workshop at Southdowns have been really helpful too.
Nigel, I think you may be trapping the water inside the door seal unless there is a gap in the bottom of the seal rubber to let it out.
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
Could try a bit of Vaseline on the seal.
Martin
44
24
Burstner lysoe 744
I know this is an old thread but we have the same problem. A small drop from the red cap. Did you resolve the situation. If so can I have the info. Many thanks
Basildog
2,201
3,576
Go to the plumbers merchant and get a tube of fernox lsx leak sealer a type of liquid non setting silicone in a tube. Guaranteed fix and the cap will still undo
Exactly what I was going to say and yes I have sealed a few of these water tank inspection hatches with LSX myself in the past .
Always keep a tube in the van as well ?
44
24
Burstner lysoe 744
Thanks. That's great.
Mr Rusty
37
30
Bedford
Burstner 690G
Since 1986
I have the same problem and even tried using a rubber seal instead of the foam one but the damn thing still leaked. Pardon the ignorance in how to use the LSX product, can I assume you just smear the gasket in it before screwing the red cap in place or are you replacing the gasket with the LSX?
Basildog
2,201
3,576
Hi yes LSX is a silicone sealer so you leave the rubber gasket or O ring in place and just apply a nice bead on to the gasket and possibly some on the cap before putting the gasket on .
Screw down reasonably tight and it’s done .
Certainly works for me .
1,302
736
Norwich
Carthago A class
Since 2014
As one of the original contributors to this post our seal seems to be holding. However I still have a piece of gaffer tape under the seal to divert any water as well as a cloth at the bottom of the tank. Belt and braces!
Basildog
2,201
3,576
I have had several different vans where the inspection cap has leaked when the tank is completely full ⚠️??
Amazingly many owners on a different group say they never fill up with water completely, as we mainly camp away from sites that would render our van totally unusable.
People are funny ?⚠️
Allanm
5,431
9,191
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
We have the same red cap on the side of the tank but ours came with a rubber seal. I have undone the cap a couple of times to clean the tank ( though it was never dirty inside) and it has resealed perfectly.
We always travel with a full tank even if we decide to stop on a campsite ( which we only ever do in the U.K. ) and there have been no leaks.
Basildog
2,201
3,576
There’s always one ??
tonka
10,797
21,441
Cannock, Staffs
A class Burstner 800
Since 2000
Thread. On Facebook days a 120mm X 5mm o ring off eBay..
Being the owner of an Elegance my tank is mounted up the right way with the red cap on top. ??
Mr Rusty
37
30
Bedford
Burstner 690G
Since 1986
I bought a rubber ring off eBay to try but the thing still leaked. I will try LSX - thanks for the tip.
128
268
Durham
Rapido 8094DF
Try just putting a thin layer of Vaseline on both sides of the seal.
48
100
Burstner Lyseo 728
Since 1995
If you've got one of these tanks, you might want to consider swapping the filler cap for one of these.
Amazon product ASIN B088GVLT88
Just attach your hose via a standard push fit connector and no messing around waiting for it to fill
Already done that and agree it’s a nice addition. Also made a matching bung to plug on when I have finished filling up.
I have also added a motorised grey water dump valve with dual controls in the water tank locker and on the dashboard... very handy.
I’m planning to add a waste camera soon so that I can position the van and dump the waste without even leaving the driver’s seat 😀
Mr Rusty
37
30
Bedford
Burstner 690G
Since 1986
Stealaway - tried the rubber O ring (bought one off eBay) and it still leaked.
pxh38257 - tried Vaseline and it works for a few days but after a week or so of the tank emptying and being filled it started to leak again.
I even got my dealer to provide me with a new Burstner seal but no luck.
Also this is the second Burstner I have owned with this type of tank and both have leaked. I have to say it is not much of a leak and I have the gaffer tape ‘fix’ between the tank and the door frame, so at least the locker floor doesn’t get wet anymore, but it is annoying.
Only thing I have tried that has worked is the LSX as mentioned by Basildon.
48
100
Burstner Lyseo 728
Since 1995
That
I've just bought one of these.
I've not had chance to fit it yet but I hope it does the trick.
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=372743295344
That should work a treat if you make sure it’s tightly sealed.
Also, look out for any scratches on the mating surface of the tank. Mine had a few scratches which I think were probably made during manufacture when the centre of the fill hole was cut out. These will need removing with an abrasive polish. I think I used T Cut to get rid of mine but don’t let any get inside the tank!
1,325
2,403
Surrey
Rapido 854f
Since 2012
Bit confused by the reference to emptying and being filled as we only undo ours now and again for a deep clean. We use another container for drinking water which is much easier. Perhaps you use yours for everything?
