Burstner Ixeo Time it585
Discussion in 'Motorhome Chat' started by Toffs-G, May 1, 2013.
  1. Toffs-G
    Toffs-G Read Only Funster
    Sep 16, 2009
    606
    110
    West Sussex
    Just come across this model of Burstner in our endless search for a compact but convenient MH.
    http://youtu.be/-RhdcCoGeSQ
    I remember many years ago :Eeek: when the MH show was at Earls Court I looked at a Burstner which if I remember was their first year manufacturing Motorhomes
    This looks on the face of it to be ideal for us or indeed the slightly larger it590 which has a seperate shower. There is only Cathy, Alexander and I and we don't have a problem making up one of the beds each night after our neighbours who have been doing the same for 23 years (in the same MH they bought from new ) gave us some time saving tips.
    We like the idea that this it is under 6m which must make it a very easy MH to run around in. Bit different to the RV which was 9.7m :Eek!:
    This also has a 720 kg payload and 120l fresh water tank.
    Hopefully getting closer although need to find a secondhand one with hopefully an auto box as Cathy doesn't drive a manual - Fingers crossed:thumb:
    G
  2. Trikeman
    Trikeman Read Only Funster
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    What a cracking MH - that dropdown is a good use of space, though does put the word 'compact' into perspective.. as usual, Burstner's really pack a punch and does use just about every inch - well designed.
    Never seen an auto though.
    Go for it......
    Good luck,
    Trikeman. :Wink:
    • Like it Like it x 1
  3. Toffs-G
    Sep 16, 2009
    606
    110
    West Sussex
    When I first showed it to Cathy her reaction was how can they do all that in such a small space? but they do. She particularly likes the size of the kitchen:Smile:
    Seemingly from the Burstner website auto is an option but finding one might well be the tricky bit
    G
  4. hilldweller
    Dec 5, 2008
    27,567
    26,682
    Macclesfield
    Can't work the beds out. The drop down bed squashes the other two berths below it. Also, even with just 2, one can't go to bed early without squashing the other person.
    Otherwise looks good.
    But not as good as our 10 YO one, they put the oven on the work surface which frees a huge volume for storage. Same oven and cooker as ours.
  5. Chockswahay
    Chockswahay Read Only Funster
    May 29, 2012
    3,097
    4,801
    We looked at one of these.............very nice indeed (but very expensive new). The bed is quite an engineering triumph however it does limit the head room of those below and is a fair climb up the ladder to bed.
    The 'lounge area' is also a good size but the small seat behind the driver does get in the way a bit. The seatback cushions also have to be removed from the wall in order to lower the bed. The other thing we noticed is not a lot of room for pillows and duvet when the bed is 'up' in the roof.
    The end kitchen is really nice and roomy and so is the toilet/shower room.
    For us the REAL drawback is that this particular van has very little storage (no garage) and we would quickly run out of space to store all our kit.
    It is a lovely van but in the end we decided that a panel van conversion gave us more of what we want from a motorhome (and about £15000 saved in our bank too !).
    It is a personal choice, I woud just say think very carefully about how much space you need for all your gear.
    (lastly, our panel van is narrower too, so even easier to drive and park :Smile:)
    Either way, good luck and have have fun with deciding :BigGrin:
  6. Mel
    Mel Funster
    Oct 6, 2012
    2,117
    2,144
    De Haan Belgium
    Dont forget the auto was only if you had the 3.0lt.
    They only brought the auto option on smaller engine late 2011 maybe 2012 in the UK.
    Cant see there being a lot with the big engine.
    But you never know best of luck.
    Mel
  7. Toffs-G
    Sep 16, 2009
    606
    110
    West Sussex
    I know what you mean and something we need to checking out I.e. the height for those underneath when the bed is down but I get the impression no different to bunk beds and as one is junior might be ok.
    Interestingly in researching these Chausson have a similar van that the bed has three heights the upper being high enough to allow seating underneath. Not sure how practical that is depends on the height of the domed roof I guess.
    All part of the fun of searching :Smile:
    G
  8. Toffs-G
    Sep 16, 2009
    606
    110
    West Sussex
    Thanks for the heads up:thumb:
    We really need to get this one right.
    From the point of view of kit we don't really have that much now. When we had the Elnagh Baron 46 it had a garage and we just filled it with everything we didn't need :Eeek:
    Then with the RV there was a dramatic reduction in what we carried as it didn't have as much storage and quite a bit less payload the Elnagh had close on 1000 kg the RV only 600kg so we needed trimming down dramatically and a fair bit of that was carrying an RV spares shop around with us:Eek!: so hopefully and we will see we might be ok but thank you for your point on van conversions something we must check out.
    Cheers:thumb:
    G
