Burstner Ixeo 590
Discussion in 'Burstner' started by KAL 590, Oct 7, 2016.
  1. KAL 590
    KAL 590 Funster
    Sep 29, 2016
    12
    Scotland
    Got our 590 a few days back, 2013 model. We have a few questions which I hope someone can help with? At each side of the lounge window there are pockets that attach with Velcro to the walls, can someone advise there purpose?
    Also we like the functionality of the table how it spins and slides etc, but this thing is mahoosive....has anyone fitted a smaller table or different type of table? I know it's purpose for additional bed but there are just the two of us so this function is not needed. I have seen tables that hinge and fold in the middle. Just wondered if anyone has got something different that could be shared?
    Kevin
  2. movan
    movan Funster Life Member
    Dec 2, 2009
    14,250
    26,124
    Moving around
    Congratulations on your lovely purchase .. can you attach photo of the pockets .. can they not just be for newspaper or tv clicker or something.
    Yes people have changed their tables and I am sure they will be along to help you very shortly.
  3. Xabia
    Xabia Funster
    Jan 20, 2011
    795
    523
    Rural Nottinghamshire and Spain
    Hymers have ginormous tables so took mine out, bought a Fiamma table leg system that consist of a base plate, column and top fitting which attaches to a table I had made to my measurements by Rainbow Leisure. The table lives in the drop down bed, column in the wardrobe. When we stop for lunch, cuppa etc just a couple of minutes job to slot the column into the floor plate, table onto column and away you go. The system is quite solid.
  4. KAL 590
    KAL 590 Funster
    Sep 29, 2016
    12
    Scotland
    Thanks Movan, yes we did think it may be for storage of remote etc, was just wanted to know as we are puzzled.
    Thanks Xabia, will have a look at Rainbow leisure, a smaller table top that folded in half would be perfect for our needs.
  5. Cervantes
    Cervantes Funster
    Jan 13, 2011
    14
    11
    Pilar de la Horadada, Spain
    Hi Kal,
    We also have a 2013 it590, and also have no idea what these are for. We use them for the TV remote, serviettes, and dried flowers. We have asked many people, but have not yet had a sensible reply.
    As for the table, we lived with ours for 3 months, then removed it ( only 4 screws holding it to the floor, so easily removed and stored under the spare bed at home) and replaced it with a free-standing one (from Carrefour) which folds flat and stores behind the passenger seat when travelling, bungeed to the seat base.
    As you can see, there is more than enough room for beer on it!!
    Hope this is of some help.
    Brian
  6. GuyandJean
    GuyandJean Read Only Funster
    Oct 29, 2016
    Wiltshire
    Hello, I wonder if anyone can help. We have had an Ixeo time 590 since June 2015 and are very happy with it. When we bought it it was 2 months old and already had a Fiamma bike rack fitted. If our bikes are loaded the rack blocks access to the toilet cassette door so, to empty the cassette, bikes have to come off the rack so we can open the door. Not the end of the world agreed but it can be irritating. Has anyone been able to work around this or is it something we just have to accept?
  7. Cervantes
    Cervantes Funster
    Jan 13, 2011
    14
    11
    Hi Guy and Jean,
    The exact same thing happened to us!
    When we bought the van we specified a cycle carrier, but foolishly didn't specify where we wanted it.
    When we picked it up, instead of being above the cassette door as I expected, it was offset to one side of it. This caused us a problem with the size of bikes we could carry (see https://themotorhomeyears.blogspot.co.uk/2013/11/teething-troubles.html ) which we overcame by getting 20" wheel bikes.
    As you said, the cassette door would not open without the cycle rack being in the closed position.
    After a great deal of head scratching I decided to drill another hole in the cycle carriers arms, and then moved the rail that carries the bike further away from the back of the van, making sure that there was then enough room to pull the cassette out of the van.
    I don't know where your cycle rack has been fitted, but if it's the same as ours, this fix should work.
    You have to find the right positions for the pedals, seat height, handlebars, rail position, angle of the bike rack and bike clamps, etc to get the bikes to fit side by side now they are closer together, but they will fit eventually - just make sure you put them in the same position every time.
    The cassette does come out with the bikes on the bike rack, but once you have pulled the cassette out of the van, you have to lift it up parallel to the back of the van, so best not to let it get too full!
    Hope this is of some help to you.
    Brian
  8. GuyandJean
    Oct 29, 2016
    Wiltshire
    IMG_0454.JPG IMG_0452.JPG Hi Brian
    Many thanks for your help. Looking at your pictures I can see that we have a different problem. With you it was the bikes that were stopping you being able to open the door to the cassette but with us it is the actual bike rack. When the rack is pulled down for the bikes it actually blocks the door from opening, but when the rack is pushed up there is enough clearance for the door to open.
    I think that if the rack had been installed just a couple of inches higher there would be no problem. Not sure if it would be advisable to move the rack up a couple of inches, don't really like the idea of extra holes being drilled in the van!
    See pics above. All the best Guy
