Burstner information/weight/data plate (1 Viewer)
oaktree11
53
26
Cheddar, Somerset
A Class Burstner i640G
We are new to motorhomes!
Hi there,
I have just purchased an Aviano i640G A class, made in 2008.
Neither the dealer nor I can find a Burstner plate. There is a fiat one (see pic) but nothing that I can find from Burstner.
Anyone got any ideas about whether there actually IS one and if so where it might be hiding?
Thanks - John
Teddyj
35
139
St Neots
Since 2009
Hi oaktree
On our Ixeo the Burstner wt. plate is low on the body just behind the drivers door,hope this helps.
Ted
movan
21,492
120,753
Moving around
Burstner
since07
If it's anything like my fuses and my battery .. it could be .. well.... anywhere!
(GJH may be able to help you.. :))
oaktree11
oaktree11
53
26
Cheddar, Somerset
Ah! thanks guys. Unfortunately I have no front doors! Just a habitation door and there is nothing around that.
I seem to have found all the batteries and at least some of the fuses!
John
GJH
29,450
38,827
None, now sold
2006 to 2022
On the first photo Here it looks like the plate is just behind the offside front wheel arch, which is equivalent to where ours is.
oaktree11
oaktree11
53
26
Cheddar, Somerset
Thank you Movan, that is kind of you and we ARE very fortunate although I did have to sacrifice my much loved car to achieve it ...sigh!
oaktree11
oaktree11
53
26
Cheddar, Somerset
Sorry for the delay in replying. Yes I think you are correct. My plate is missing. If you look at the attached pic of my MH you can see the different colour area where it should be. I have got a copy of the cert of conformity with all the data so I am not too worried. I wonder if I can get another one?
Thank you all for the help
John
Reactions: GJH
Lenny HB
53,408
149,870
On the coast in West Sussex
Hymer B678 DL
Do you have the serial number of the van, unfortunatly it's normally on that plate, but shold be on the Certificate of Conformity armed serial number you should be able to confirm with Burstner the plated weights.
oaktree11
oaktree11
53
26
Cheddar, Somerset
Yes, the cert has all the weights etc, I will take a photo if it tomorrow and post.
John
Emmit
8,032
17,747
Cornwall
Pilote Explorateur
Jan.2014
I appreciate that this thread is over five years old but, for the info of others, it may have been the case that the owner before the OP had the original weights altered by applying to DVLA via SV Tech. Having got a new 'Plate' the old plate was removed. I've seen an original plate on a Burstner inside the engine compartment.
Lenny HB
53,408
149,870
Hymer B678 DL
For a start you are not supposed to remove the original plate.
The plates in the engine bay will be the base vehicle and if an Al-Ko chassis there will be an Al-Ko plate. The last plate fitted supercedes previous plates so on a standard conversion the converters plate is the only one that matters. If the vehical has been uprated by SV Tech the SV Tech plate is the one to go by the others are irellavant.
Emmit
8,032
17,747
Cornwall
Pilote Explorateur
Jan.2014
Lenny HB
You wrote, "For a start you are not supposed to remove the original plate."
I know I am not supposed to remove Plates. I didn't.
Everything you have stated, I understand. I was only offering a plausible explanation
as to the circumstances.
And, further to that, the last Burstner I viewed didn't have an Uprated Plate. It had a downrated Plate. Under those circumstances it is even more plausible that someone, erroneously has removed the Downrated plate because they again wrongly thought that by doing so would return the van to it's original plated weights (even if the original plate had been removed) The van I saw did indeed have its Plate situated on the offside, under the drivers side window.
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Typical Burstner plate. 2012 T660 Already showing signs of coming adrift.
Emmit
8,032
17,747
Cornwall
Pilote Explorateur
Jan.2014
Following Stealaway's Post (above) am I the only one who can see the problem with Burstner posting their Plate Cert complete with Chassis No. in a place open to public view.
Jul 6, 2009
1,794
2,214
Our 2019 Iexo 736 A class has Burstners plate just inside the hab door low down on the right hand side as you step in.
Jul 29, 2013
9,069
18,496
Salisbury
Hymer B678DL A class
since 2011
I think you will find that on most Hymer group vehicles the plate is already on display on the outside of the van as is ours🤔
