Burstner - Gas BBQ Enquiry (1 Viewer)
topbrief
5
Leeds
Hiring
Newbie
Hi All,
I'm a bit of a newbie so please bear with me if I get some of the terminology wrong.
My family and I are about to hire a Burstner Elegance for our Summer holiday. The very kind lady from Harrogate Motorhomes has already shown me around the vehicle and I remember that there was a gas outlet on the side of the vehicle (outside the kitchen) for connection to a gas BBQ.
I am considering buying a second-hand one on FleaBay (other auction sites are apparently available) for us to use over the course of our fortnight away. So far I have identified the Cadac Eazi as a likely contender.
So my questions...
Will a CADAC Eazi fit / work?
Will I need a separate regulator or is the supply sufficiently regulated by the pre-existing regulator?
Are there any better alternatives?
Thanks in advance.
topbrief
Dai
47
24
West Wales
Since 2000
We have an Elegance which has a gas point fitted as an extra. Therefore it is plumbed in after the regulater.
The newer models I believe come with a gaspoint already factory installed. I recommend you contact Harrogate Motorhomes for confirmation.
Sorry cannot help on the other queeries
Dai
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
The supply will be regulated by the van's gas regulator, but you will need to buy a suitable connector that matches the outlet on the Burstner (probably a Reich outlet point if factory-fitted) and connect this to the rubber gas pipe of your Cadac.
Chris
21,006
274,542
None
10 years
Sorry I can't help.
Nice van you are hiring though.:thumb:
cbrookson
389
427
Suffolk
Le Voyageur RX9 2012
Since 2001
Just make sure you get a LP - Low Pressure - one. The HP (High Pressure) work off a pierceable gas cartridge and will not work off an external gas point properly. :Doh:
Ridgeway
3,624
6,053
Lausanne
NiBi Arto 85E
Since 2012
I'm sure that the hire company will be happy to supply the motorhome ready to go with all required adapters so that you would only need to turn up with the BBQ itself.
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
Hi topbrief
We are hiring the same van on Sunday. hope you had a good trip in it. How was it on fuel and where did you go?
