Burstner control panel
Discussion in 'Motorhome Chat' started by StigsMarta, Jun 1, 2016.
  1. StigsMarta
    StigsMarta Funster
    May 28, 2016
    8
    8
    Sweden
    My Burstner Elegance i 810 has a control panel named "LT510".
    There´s LED-lights that tell the water and wastewater levels. When I push the water button it tells me levels via the blue lights (0-100%) and via the "picture" of the tank. The blue lights seems to be working just fine, the levels indicated are correct. The problem is; when I push the button the water tank lights are flashing and the "picture" of the fresh water tank flashes in red.
    I can´t understand whats wrong or how I shuold fix it. The manual says that red flashing lights means the tank is empty, although the bleu lights tells the right levels? It´s not a huge problem of course, since levels are reading right, but I would of course be happy to find the reason...
    Maybe I just need to reset it or something? I tried to pull out the fuses, also the ones for the living-part batterys, but it didn´t help. Any ideas welcome! :)
    I read that @Mikey RV had this problem a couple of years ago, do you remember what you did to fix it Mikey? ;)
  2. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,091
    1,221
    Dronfield - Derbyshire
    I would suspect the sensor. Have a look inside the tank to see if it's clean. It might reset if you can disconnect it.
  3. Mikey RV
    Mikey RV Funster
    Mar 7, 2010
    1,111
    3,171
    Devon
    Can't remember but I think when I next emptied and refilled it sorted out self out.
