burstner a647
Discussion in 'Motorhome Chat' started by tattoobluedog12345, Oct 28, 2014.
  1. tattoobluedog12345
    tattoobluedog12345 Read Only Funster
    Jan 29, 2014
    41
    3
    manchester/ winton eccles
    hi can anyone help please
    my n/s/top side marker light is not working, i cannot find out where the wires connect to, also I have tried the following - removing the lamp cleaned all points and refit with new bulb still not working.
    I cannot find where the wires run out, but on the o/s I can see the wires coming out underneath the corner.
    thank you
  2. Xabia
    Xabia Funster
    Jan 20, 2011
    758
    500
    Rural Nottinghamshire and Spain
    Have you tried checking the connections on the light with a multimeter to see if power is there? Reason for asking is that I had a similar problem with a rear light on my Hymer. Cleaned the contacts, changed the bulb - zilch. Checked with multimeter and no power to the fitting. Eventually found that it was due to a poor earth connection, cleaned that up and it worked fine.
    Mike
  3. tattoobluedog12345
    Jan 29, 2014
    41
    3
    thanks for your reply I have tried all that you have said no power but I cannot see where the wire from n/s top marker light comes out from, yet on the o/s I can see where the wire come out and fit to the rear lamp.
    if I could fine the end of the marker light cable I would have just connected it to one of the side marker lights.
    so I am stumped now if at first I don't succeed I will try and try again.
    thank you
  4. tattoobluedog12345
    Jan 29, 2014
    41
    3
    please can anyone help
