burning oil and only 30,000 on clock (1 Viewer)
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
Hi all from damp Rhineland, my Fiat Ducato 2003 has just started to burn oil for no apparent reason, the engine is running well and no other problems.
The blue smoke is present when the engine is hot and the the engine is ticking over, ie stopped in traffic, as soon as I move of the smoke gets thicker but quickly disapperes after 20 or 30 seconds.
I think it is the turbo charger seals the are leaking, any one else experiance this???
Doug....
ourcampersbeentrashed
7,574
4,348
East London
well over 5 years
Hubby says you could be right about oil getting into the turbo, otherwise it could be that the rings have gone or are starting to go.
We have had 2 fiat ducatos with no problems so good luck xxxx
haganap
12,759
26,447
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
When you say burn oil can you be more specific? ie quantaties or is the old girl just smoking alot?
Is it consistant ie, everytime you stop or just on occasions?
these are a few options,
a) air cleaner element clogged or restriction in duct between air cleaner and turbocharger which can cause oil to be drawn past the turbocharger seal at the compressor end,
(b) restriction or faulty check valve in turbocharger oil drain line, which may raise the oil level in the turbocharger center housing and cause seal leakage,
(c) malfunction in oil scavenge pump,
(d) restriction in engine crankcase breather,
(e) worn or damaged compressor wheel,
(f) turbocharger shaft bearings or bearing bores worn,
Its not unthinkable to have a problem in this area. Of course possible rings etc but would of thought thats a long shot.
Harveyx
13
Northern Ireland
RV
:Smile:Had a problem like this on a car. It turned out to be valve stem seals had hardened and no longer doing their job. Not as expensive to fix as I first thought.
Pikey Pete
1,481
1,143
o
o
Valve stem seals has to be favourite. They allow oil to seep from the top end when staionary and it quickly burns off when running:Smile:
Pete
Douglas
Douglas
2,835
400
South Wales,
I done an oil change 1,000miles ago and the dipstick level has gon down about 20% of the range, I have not topped it up so that I can get a more acurate measure.
The burnt oil is present every time I come to tick over after the engine has reached working temp. The is no sign of burning on start up, cold or hot.
The air filter is clean,
The engine has only done 30,000 miles which seems to soon for any wear problems.
Doug.
M
MattC
I had exactly this problem at a similar mileage on my 2.8 and it was the turbo which thankfully was replaced whilst still under warranty.
