Bumpy roof on our MH
Discussion in 'Motorhome Chat' started by Spidey, Feb 8, 2015.
  1. Spidey
    Spidey Funster
    Jun 16, 2013
    888
    581
    Wiltshire
    Does this sound right to you, not sure if i am worrying about something and nothing :-(
    OH was washing the roof today and noticed that the front part of the roof appears to be bumpy, quit big bumps. This is on the flat part of the roof. Also the masking stuff around the front of the roof appears to have black mould in it.
    We have taken a photo so will try to upload it later. Should we be mentioning it to our dealers?
  2. Munchie
    Munchie Funster Life Member
    Jul 28, 2007
    8,577
    11,795
    Champagnac-La-Riviere
    Yes! Sounds like delamination!
  3. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,027
    6,045
    West Sussex
    What make is the van? Is it an aluminium or GRP roof?
    GRP roofs are often not bonded so can move and ripple but should only be slight if they are large bubbles you may have a problem.
  4. Spidey
    Spidey Funster
    Jun 16, 2013
    888
    581
    Wiltshire
    Its a chausson flash 510, o dear don't like the sound of delimitation
  5. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,939
    West Norfolk
    Our polyester roof on our Chausson has always been bumpy. It was like it new.
    It's just a very flexible construction.
    • Like Like x 1
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,903
    17,577
    YO11 2BD
    Don't worry about the black marks.
    I think it's a fungal growth within the sealer.
    It's normal and won't cause any problems.
  7. Spidey
    Spidey Funster
    Jun 16, 2013
    888
    581
    Wiltshire
  8. Spidey
    Spidey Funster
    Jun 16, 2013
    888
    581
    Wiltshire
    Does that look normal?
  9. Spidey
    Spidey Funster
    Jun 16, 2013
    888
    581
    Wiltshire
    Also while i am on a roll. Took e MH down to the garage and there was a lot of rattling from what seemed like inside the facia at the bottom of the roof window. Could bits get into that area?
  10. PaulyP
    PaulyP Funster
    Jul 29, 2011
    1,812
    3,066
    Manchester
    Looks just like mine - no leaks from it.
    • Like Like x 1
  11. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,939
    West Norfolk
    Yep we have similar ripples!
    • Like Like x 1
  12. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,888
    somewhere
    yor dooooooooooooooooooomed dooooooooooooooomed I tell yeeeeeeeeeeee :Eeek:
    • Like Like x 2
  13. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    1,952
    1,697
    Bungay Suffolk
    I didn't think mould could grow on good quality sealant.. But it should still be doing its job.. I wonder if the dealer would "rake" it out and re-do it ??
    Be reassured by the other folks with like vans who have the same 'ripples'... :)
    • Like Like x 1
  14. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    dont panic, some grp roofs are not bonded but float as they expand and retract with the temperatures...stops them cracking. check with dealer to find out how its constructed
    • Like Like x 1
  15. IanF
    IanF Funster
    May 7, 2013
    2,190
    643
    Redcar- N.Yorkshire
    It is a Polyester 54 mm thick reinforced roof designed to move/flex in different conditions. While it might be unsightly, they have as much as I have researched, an excellent positive record on the lack of water ingress.
    • Like Like x 1
  16. scotjimland
    Jul 25, 2007
    28,934
    25,601
    I would clean the black mold off.. if left it will continue to eat into the sealer and may eventual cause it to leak..
    Use a soft brush and scrub with soap and mild bleach solution or buy a fungicidal cleaner..
    For peace of mind I would have the roof checked by the dealer..
    • Like Like x 1
  17. BobtheBass
    BobtheBass Funster
    Nov 11, 2013
    683
    1,772
    Tewkesbury
    Just checked my one month old Chausson 718 and yep, the front section of the roof is rippled just like the photo above. Strange I hadn't noticed it before as the van is parked below my bedroom window and I see the roof every day, so I guess it must be temperature dependent?
  18. Spidey
    Spidey Funster
    Jun 16, 2013
    888
    581
    Wiltshire
    I can see our roof from bedroom window, but never noticed it. Mind you it was a bit dirty as park near trees. Only when hubby cleaned the roof we noticed o_O
