Built in Water Filters?
Discussion in 'Motorhome Chat' started by Cocoro, Jan 31, 2013.
  1. Cocoro
    Cocoro Read Only Funster
    Nov 5, 2011
    62
    112
    Europe
    Anybody have experience of fitting a water filter to their van? I'm looking for a plumbed in affair with decent pressure/flow. Asking too much?
    I have a sureflow water pump which seems quite powerful. Well, better than the ones that dangle inside the water tank anyhow.
    I tend to carry around masses of volvic which is ok as it makes the tank last longer but it's the shopping for them that hurts. Both the cost and the lugging it around if you can't park near enough to the shops.
    Any thoughts? Are they worth it?
  2. pablomc
    pablomc Funster Life Member
    Apr 20, 2010
    860
    235
    Durham
    I have had a nature pure water filter in my last two vans. Have a separate tap (facet) connected so I only use the filtered for drinking/ cooking.
    Worth very penny in my opinion even if just for the convenience.
  3. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,227
    16,810
    Liverpool.
    Same here, bought with funster discount direct.
    • Like Like x 1
  4. Cocoro
    Nov 5, 2011
    62
    112
    Europe
    Hi,
    Which Nature Pure system did you buy? and how is the pressure?
  5. canopus
    canopus Funster Life Member
    Nov 27, 2010
    3,105
    3,478
    Lincolnshire
  6. pablomc
    Apr 20, 2010
    860
    235
    Durham
    I went for the QC version just for ease of removing during winter drain down. The previous van had the one canopus has linked.
    You couldn't have a shower under it, but its sufficient to fill a kettle or jug to put in the fridge. Its down to the pump in your van but it could pulse, but I never found this a problem with our old van. You could probably add an accumulator to take up the slack should this be an issue.
  7. scotjimland
    Jul 25, 2007
    28,934
    25,601
    Another vote for Nature Pure.. :thumb:
    best and the first accessory you should buy
    • Like Like x 1
  8. Snowbird
    Apr 24, 2009
    10,227
    16,810
    Liverpool.
    I dont understand why you would want to filter shower water. If the filter is any good at filtering nasties out, then its expensive to replace so why would you want to risk clogging an expensive filter whilst having a shower.
    Just my thoughts, maybe there is some other reason but I only filter drinking water through my nature pure and I never drink the stuff anyway unless it has caffeine in it.
    • Like Like x 1
  9. canopus
    Nov 27, 2010
    3,105
    3,478
    Lincolnshire
    Who mentioned a shower - read again Dave its says S L O W E R
    :Eeek::Eeek::Eeek:
    • Like Like x 1
  10. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,732
    5,962
    Mansfield,Notts
    It reads SHOWER to me too:RollEyes:
  11. TheDogMan
    TheDogMan Funster
    Mar 29, 2011
    679
    388
    Rugby UK
    I just used a filter jug last year and filled it from the tap, the water tasted fine, I changed the filter twice during the season.
    Dave
  12. scotjimland
    Jul 25, 2007
    28,934
    25,601
    Legionella.. ? :Laughing:
    can't be too careful Dave :Wink:
    • Like Like x 1
  13. Swiftroy1
    Swiftroy1 Read Only Funster
    Jan 3, 2010
    180
    172
    Bedfordshire
    I must be missing something here. Why would you want to use a water filter? I've never had a problem with drinking water out of my tank where-ever I filled it from. Do I have an iron constitution or have I just been lucky?
    Roy
  14. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,888
    17,547
    YO11 2BD
    depends where you get your water from Roy.
    in desperation, have you ever filled from rivers, lakes, ditch's , puddles, horse troughs etc......you can with a General ecology (nature pure) water filter.
  15. Swiftroy1
    Jan 3, 2010
    180
    172
    Bedfordshire
    I hadn't thought about that Pappajohn. I've never needed to fill from anything other than standpipes.
    Roy:thumb:
  16. pappajohn
    Aug 26, 2007
    29,888
    17,547
    YO11 2BD
    and hopefully you will never have to do otherwise :thumb:
    • Like Like x 1
  17. barrybus
    barrybus Funster
    Mar 3, 2011
    27
    6
    St.Neots Cambs
    Pure water supply?
    Not sure where I heard /saw/read about it,but I recollect something about cowboys,explorers useing silver coins in their water bottles to purify it.Dont know for sure just a suspicion? Barry.
  18. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
    i fitted one of these in the line just to the sink tap. if you shop about youll get one and push fit fitting for about £45.
    took an hour to fit and most of that was moving panels to get at the plastic pipe to the sink.
    no taste or smells on water we drink.:thumb:
  19. scotjimland
    Jul 25, 2007
    28,934
    25,601
    Your absolutely correct.. water from standpipes in Europe will always be potable .. no need to filter.. not so the case in Morocco where we were very glad we had it as we had to on occasion fill from a well..
    however, in addition to what John said, there is always the possibility of introducing bacteria from the van's tank or pipework.. a small risk.. plus, after filtering it tastes so much nicer.. the filter removes chlorine.. important for making a great cup of coffee.. no need to ever buy bottled water again.. it will soon pay for itself..
    Cartridges are quite expensive, IIRC about £50 .. but it will last several seasons.. provided it's not in the shower :Laughing:
    • Like Like x 1
  20. scotjimland
    Jul 25, 2007
    28,934
    25,601
    I'm sure it does that, .. but does it also remove cysts, Protozoa, Bacteria, Viruses, Organic compounds and Chlorine. etc ?
