Bubbling on the bodywork (1 Viewer)
DavidEJM
38
Oxfordshire
C class
Over the past 12 months or so the stripe on the side of our Compass Drifter has started to bubble in places. Now usually (in my experience with old cars) this points to rust, but of course the side of the van is aluminium.
I have peeled the sticker back and sure enough there is a dry powder (oxidisation) behind and a small hole in each instance through which I can see the insulating foam.
Anyone have any thoughts on the cause? (not there when we bought the van and the stripe appears to be original) and what is the best way to repair?
I'm reasonably competant having worked on car bodywork up to the point of restoring and respraying cars, but never with aluminium. I know of products that you can use to effectively weld ali (blow torch on screwdriver blade, 'tin' the screwdriver with product and wipe over hole..........one of those things you see at shows, get home and find that it takes years of practice to use effectively) and I might take this route. Or does someone have a better (for which read simpler) idea?
And finally...... what is the thought on striping? keep it original or do your own thing? Will this have any effect on resale values (keeping things looking original)
Well hope that makes sense and thanks in advance.
Tony Santara
1,372
116
Cheshire (ex Mancunian)
A class RV
since 1994
I would choose the easy option ....clean up the affected area by sanding and fill the hole with P40 body filler take it down smooth with wet & dry sanding paper spray it with primer and restripe over it.
As for striping I did my own thing on my old Winnebago not to original but my own design made for me and applied by my local vynil sign maker it didn't affect the sale of it later made it more individual :Cool:
Good luck :thumb:
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Clean the corrosion out thoroughly and fill with plastic padding or similiar, rub down until smooth and get a new stripe made from a local signwriter (get two, one for the other side to colour match)
Use fairy liquid in water to allow the new stripe to slip into position you want and rub out any air bubbles with a cloth.
Peter
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
Hi David you have already identified your problem as -tin worm- It will be almost impossible to weld leaving you the option of filling etc or replace the full sheet :Eeek::Eeek:
Personally I think it will keep coming back every few months :Eeek: chances are it will have come from the inside out :whatthe::whatthe: Since normal vans are only .5 mm thick ali one hole will lead to another,not what you want to hear :cry: Look seriously at getting rid :thumb:
Drastic I know BUT
terry
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I'd pick a convenient hole and peel it back to find out why ? If it's damp from behind you need to know now.
Or was it a hole in the original stripe ? Maybe someone pricked it to get rid of a bubble. ?
DESCO
2,646
266
London
low profile
18 years +12 years tugging
Drastic I know BUT
terry
Had similar on first motorhome years ago, did as terry advises and got rid ASAP.
Dave:thumb::thumb:
43,319
49,397
i'm inclined to agree with Brian.
a shoddily applied sticker and its been pricked to get rid of the air bubbles.
the "pin" has probably also pierced the protective coat on the ally skin and allowed water in.
metz
9
Hi, Sounds like osmosis to me, usually caused by damp reacting with the adhesive used to bond the Ally to the insulation, or the Ally is in contact with a dissimilar metal, sand down clean up fill and refinish is just about your only option, needs checking for damp though, and if any found, the problem area repairing.
DavidEJM
DavidEJM
38
Oxfordshire
C class
mmmm, thanks all.
Some worrying comments there, can't really afford to get rid at the moment so will have to effect some repairs. Looks like I will be having a busy winter!
The affected areas are very localised (small holes generally) and seem to match the suggested badly applied sticker (or more likely that is the answer i want:Smile:) Not sure how damp from behind could be the cause because there is foam directly behind these areas with no evidence of damp there.
I will carry out a more detailed inspection over the next few days and see if a cause can be found, because that is now my main concern.
So, whilst you’ve put the wind up me............... thanks.
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
Aluminium corrosion once started is very difficult to control, on aircraft the affected area is mechanically cleaned until there is no pitting visible with a high powered magnifying glass, a jewelers loop or similar.
After this the area is treated with Chromic acid or paint containing chromic acid (Etching paint) and then a top coat if the area is external.
In your case this kind of treatment is going to be difficult as you can not get at both sides of the metal and it is to thin for this method.
It is certain that covering the area is not going to stop the corrosion, it will continue underneath anything you cover it with. all be it very slowly.
On an aircraft the effected area would be cut away and a new section of identical metal would be riveted as a patch. this is also would be very difficult for you as you don't have access to both sides of the metal.
I would think that the application of chromic acid or etching paint containing chromic acid is your best way of treating it but I do not know what effect the acid would have in the foam insulation that will be on the inside of the aluminium skin.
Link Removed
http://www.finishing.com/1200-1399/1318.shtml
Link Removed
Link Removed
Doug...
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Camping Caravaning now 5'ering 49 years
Doug...
Totally agree Doug
Thiis is exactly what we do with Land Rovers that suffer with the same problem - we find it does a pretty good job and can last a considerable number of years - once the white powder has been removed and the surface roughed up with wet and dry we clean with a clean lint free rag with a small amount of cellulose thinners on it - allow to dry and then spray or if a very small area with and artists brush. We then paint as normal. Always worth checking compatability of paint systems first though. Most good commercial paint suppliers can advise on this though.
DavidEJM
DavidEJM
38
Oxfordshire
C class
All great advice chaps, I knew I should have asked about this sooner!!
Just had a scrape at one of the bubbles and the 'infliction' seems to be going from the outside in, as the ali is not perforated (yet) just lightly pitted. I will get some of this etching paint, get the dremel out, and go for the repair.
I will take some photos and show the steps I take, you can then stop me if I've done something wrong or it may be useful to others with the same problem.
David
