Broken TV aerial - help
Discussion in 'TV & Satellite' started by Viennese, Oct 25, 2010.
  1. Viennese
    Viennese Funster
    May 21, 2008
    2,365
    2,564
    Oxford
    Our TV aerial on our 1998 Autosleeper Symphony got broken by a low branch recently - we would like to remove it and fit a cover as we don't watch tv in the van. Any suggestions as to how we do this? Autosleeper will do it but with driving there and getting it done it will cost over £100, which after a month abroad we are reluctant to spend. However, we are worried that water will get through the yards of duct tape holding it together.
    Many thanks
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    better to have it replaced you will not want to keep the van for ever and buyer will expect an antenna.
    Insurance job, Local caravan/motorhome repair shop.
  3. Phil_Mart
    Phil_Mart Read Only Funster
    Sep 24, 2010
    32
    North Shields Tyne & Wear
    Quick fix, cut out the side of a plastic box a little bit bigger than the hole. Clean down the glass around the area and then stick the plastic sheet down with some silicon bathroom sealant. That should keep you dry until you can get the hole glassed in.
  4. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,685
    5,832
    Mansfield,Notts
    Disconect the arial cable inside the power booster, remove broken arial pull out the cable you disconected along with the arial
    Fit one of THESE in its place using sikaflex sealant,and the screws.
    Your local caravan shop will have all you need, if you decide to replace the broken item, it comes with a short lead, just reverse removal instructions:thumb:
    Geo
