broken leaf spring (1 Viewer)
georgie boy
143
15
liverpool
Concorde charisma
hi
just been out fixing the step on my motorhome only to find out it has a broken leaf spring, can anybody give me any advice on were i can purchase good quality replacements i live in liverpool also do you have to replace both
its on a autotrail cheyenne on the fiat multi jet 2007
grumps147
1,840
2,448
St.Helens
Between
MH 12 yrs -Tent/Caravan 49 years
hi
try a google search using the below link - they may only carry popular ones as stock
Link Removed
The main fiat agent is on Huyton industrial estate if that fails.
Autoquest
389
36
Small EU backwater
I replaced my springs last year with the heavy duty model - brilliant
Here is a link to a discussion about thiss very topic
Link Removed
43,319
49,385
cant help with sourcing a spring but you should always fit a pair.
the originals will have weakened with age and load and to fit just one will probably raise that side to the point of being lop-sided.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
These guys here can supply uprated springs for your motor home and will deliver, A good opertunity to improve your vans suspension
If fitting standard springs you dont have to replace both but it is good practise to do so.:thumb:
If uprating, then both have to be replaced
Geo
Autoquest
389
36
Small EU backwater
I only replaced one spring to start with and i needed 0.5bar in the airide on one side and 5.0 bar in the other to keep the back end level (side to side) Go for two:Smile:
Mine cracked in exactly the same place as yours... (and it passed an MOT)
andi4x4
43
7
Ramsey, Isle of man
I'm in the same boat - I also need a pair (Yes, replace them as pairs - not one at a time ! ) - The is a company near where I used t live in the midlands called (oddly!) Midland Road Springs at Coleshill - no number at the mo, but, they will be in the directory for that area.
A quick ebay search pulled the following -
Link Removed
And
Link Removed
DESCO
2,646
266
London
low profile
18 years +12 years tugging
Looking around a few forums in the last few days have noticed a few Fiat's that are coming up for MOT's seem to be needing springs replacing, don't know if this is a trend but might be worth watching. Have put this on both spring posts
artona
1,511
817
self build
40 yrs and still not got a release date
They supplied. I found them cheaper than ebay and Carl, the guy I spoke to was very, very efficient. Springs arrived next day and I got my local garage to fit them
stew
