Broken handle return spring
Discussion in 'Dethleffs' started by aba, Feb 19, 2012.
  1. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    hi guys.
    looking for anyone who has had the inner panel off the habitation door of a Dethleffs Advantage.
    it appears at the moment that the return spring on the inner handle has either become detached or broken as the handle doesn't return to its rest position.
    it looks like the handle is installed on the door then the inner panel is fitted over the top then a trim is fitted around the handle.
    however it looks like the inner panel was fitted on the door and then the aluminium edging was fitted around the outer edge of the door to hold it all together.:Doh:
    i have emailed dethleffs and got an immediate automated response stating that the person is out of the office until the 22nd so will see how good dethleffs are with customer relations.
  2. Hayleylulu
    Hayleylulu
    Feb 17, 2008
    5,391
    3,880
    Full timing in the van
    I will put money on it that brown hills will know how:Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1:
  3. aba
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    hadn't thought of them :Doh:
    although they couldn't be any worse than the shower i bought the van off in the first place.
  4. steviebouy
    steviebouy Funster
    Jun 18, 2011
    59
    55
    Pucklechurch, Bristol
    Hi aba, how did you get on with this repair? Mines gone the same way - looks impossible without splitting the door.
    Anybody else had experience with this repair or any idea of the required parts so that I can be prepared before laying into this problem.
    Thanks, Steve
  5. JimboT
    JimboT Funster
    Nov 6, 2013
    245
    167
    Welwyn Garden City
    have you got any pictures ?
    jim
  6. Allanm
    Allanm Funster
    Jun 30, 2013
    3,115
    4,247
    Cotes d'armor, France
    What make of door is it? We have a Hartal door, we had a problem with it a while ago where we couldn't shut the door and both inner and outer handles were loose.
    It was a simple fix, on the Aire at Le Cotoy, in torrential rain......
  7. mogbl
    mogbl Funster
    Sep 28, 2010
    89
    173
    Castletownbere West Cork
    Easy fix When you get the spring. I am on my third spring. Prize off the cover around the handles, remove the bin and screws, remove the big pull handle. Then push both sides of the inner skin of the door towards the centre and you will find it just pops off. Then find the spring which will have snapped and replace.
    • Like Like x 2
  8. steviebouy
    steviebouy Funster
    Jun 18, 2011
    59
    55
    Thank you mogbl !!
    Who would have thought that the door came apart like that. I had visions (nightmares more like) of having to prise off the bead that runs around the door, looking as though it holds the two parts together.
    The seemingly impossible turned into a 10 minute job. By the way I ditched the paperclip in favour of a light coil spring on the linkage rods. Does anybody else still have a box of "Terrys" assorted springs?
    Allanm asked about the make of the door which I take to be a proprietry Dethleffs item. It is the one with the semicircular top. It has a flat exterior and a vaccumn formed inner skin which is joined around the circumference with an aluminium extrusion onto which the hinges are fixed. I originally posed the question (after searching and finding aba's original post because I assumed the look would be generic as so many motorhome parts are.
    Many thanks to all those who helped, once again proving the value of the Fun forum.
  9. Antique
    Antique Funster
    Mar 21, 2015
    30
    22
    notts
    Please forgive if this is in the wrong place (another newbie here !)
    THANK YOU THANK YOU THANK YOU . . .. . . .
    I spent a while searching the web regarding the above problem and tripped over this great site.
    In brief a few days ago I was quoted £450+ by a local dealership to repair my habitation door lock.
    (5 hours labour + parts).
    Within 15 mins following mogbl and steviebouys advice I had stripped the door and located the offending broken spring. At a local locksmith I sourced a close match and re-modelled the spring to fit.
    Oh joy and bliss . . . All went well and another 20 mins saw the door reassembled.
    Cost of one spring plus a spare £1 ! ! ! !
    So once again a huge THANK YOU from a very happy newbie who is looking forward to enjoying this friendly and informative forum.
    Antique
    • Like Like x 2
