Bridge rectifiers
Discussion in 'Solar Power' started by Wildbill, Sep 29, 2016.
  1. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,993
    somewhere
    OK this might be a daft question my diod has packed in on my soler it a 30 mile round trip to get on.
    I have a box with sum bridge rectifiers in it
    Would one of those work that only have diodes in them any way don't thay I might be wrong but I am sure someone will be along soon to sortmeout
    19v open cercut DC in DC out would it work
    Bill
  2. pyro
    pyro Funster
    May 8, 2016
    1,039
    2,816
    silver coast, portugal
    I know nothing about solar panels, Bill, but I think one leg should work in theory
    [​IMG]
    But a diode will only cost a few pence, why not wait until you can get to a store such as Maplins?
  3. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,993
    somewhere
    I Ned to get it working today as I am working the rest of the week 12hr shifts
    Bill
  4. pyro
    pyro Funster
    May 8, 2016
    1,039
    2,816
    Bugger. As I say, the bridge rectifier would appear to be usable in theory. Just that I'd hate to give advice and see things go wrong. Best to see if an expert on solar panels can advise
  5. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,993
    somewhere
    It's only 12v not like I am going to blow my shelf up but I think it could code a power reduction.
    Vill
  6. Flamenca
    Flamenca Funster Life Member
    Jun 21, 2013
    792
    485
    West Country and France/Spain
    Use just the output side of the bridge rectifier. Connect - to source and + to load. Tape the input connections. You will have 2 diodes in series but it will work.
    • Like it Like it x 1
    • Informative Informative x 1
  7. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,993
    somewhere
    thanks so + to battery I will just put insulated spade on input connectors
  8. Flamenca
    Jun 21, 2013
    792
    485
    Yes. The volt drop will be higher than for a single diode but it will be better than nothing.
  9. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,993
    somewhere
    Just checked it 2v drop giving 17v to controller
    Thanks Guy's it worked
    • Like it Like it x 3
  10. pyro
    pyro Funster
    May 8, 2016
    1,039
    2,816
    Yay! As stated by Flamenco above, the volt drop over two diodes (0.6V/diode from memory) will be greater, so that will impair charging
    Good news
  11. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,993
    somewhere
    another question capacitors am i right that if thay fale thay wont let power thug
  12. pyro
    pyro Funster
    May 8, 2016
    1,039
    2,816
    A capacitor can either fail open circuit or short circuit. Usually they are across the supply in a M/H, so a short circuit will almost certainly blow a fuse in that case. A open circuit cap wouldn't prevent power from getting through, but could allow power fluctuations to get though.
    Caps can sometimes be used in series with the supply, to allow audio or radio signals to get through and prevent DC from doing so. I'm unsure where that would be used in a M/H, perhaps and aerial, audio or signalling circuit. In which case a short circuit will cause interference with that signal, an open circuit will stop everything from passing through.
    Sorry it is so generalised, need more information to give you a better answer
  13. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,993
    somewhere
    OK my wielder stopped working it was the capasetator could no get exact mach but got one with same values.
    Only thing is I threw the old one in the bin at maplines and I an not sure now what side is in + and what side is out can anyone help. 14752450970451807600736.jpg
  14. ianthebuilder
    ianthebuilder Funster
    Oct 24, 2015
    3,679
    9,186
    Helgas house
    Hi di hi campers!!
  15. pyro
    pyro Funster
    May 8, 2016
    1,039
    2,816
    Ho de ho, Ian
    On the cap, looks like it is non polarised, Bill. Means it can go in either way around.
  16. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,993
    somewhere
    thanks working fine now the power of fun(y) :clap2:
  17. pyro
    pyro Funster
    May 8, 2016
    1,039
    2,816
    Great news. I would still change that bridge rectifier for a single diode when you get the chance, though. Make sure the current rating is sufficient to do the job
  18. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,993
    somewhere
    Done this after none by my son
    Bill
  19. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,993
    somewhere
    Now sitting in hospital with my eldest grandson broken leg fell off his bike.
    Bill
  20. pyro
    pyro Funster
    May 8, 2016
    1,039
    2,816
    Oh, bugger, you are going through it mate. Hope the little fella is all right
