Bread Crates (1 Viewer)
Debs
6,296
181,311
West Notts
A class Adria Vision
After reading about people extolling the merits of using bread crates to help grip on muddy pitches I was chuffed that our corner shop has said we can have a few(y)
Couple of questions though please - there seem to be several different types in the pile at the shop.......are some better than others & can anyone post a pic for reference?
Do You just cut the sides off and what do you use to cut it with please.
Deb
Jul 21, 2011
194
179
Up’t North West
coach built
Cut out the base the ones with triangles (well they are mine Hovis) then cut the base in half again length ways. I've cable tied these together length ways but only slack so they fold on top of each other for storage.
Colin
577
1,493
Conwy, North Wales
Relay self build
Hi Deb. It's just the base that you need - the criss cross bit which acts as a good grip under the tyres. One base cut in half should do it. I used an angle grinder on mine but I guess a hacksaw would also do the job.
Debs
Debs
6,296
181,311
West Notts
Ta for the quick replies - looking at the pile, some have a bit of a lip on the criss cross pieces and others are just smooth criss cross (iyswim).......I'm guessing the ones with the lip would give more grip?
I can't be trusted with a hacksaw but Les has an angle grinder:)
4,326
104,076
South Yorkshire
Since 1999
An electric jigsaw will cut them. I actually leave them as one, about 600mm square. OK they take up more room and weigh twice as much as if cut in half but they spread the load much better.
GJH
29,450
38,827
None, now sold
2006 to 2022
I did the same with the 10 loaf size but some are now cut down after damage. I also cut the bases of some 15 loaf ones in half as they are so much bigger.
43,304
49,293
So where do peeps get these used trays from?
You need to hunt them down.
School or hotel kitchens are a good bet as loads don't get returned.
I got mine at a local school I was doing some electrical work at.
Remember, no matter where you source them they are the property of the relevant bakery so try to remove any bakery name etc....usually stamped/embossed on the sides so not difficult as you cut off the sides anyway.
Ridgeway
3,653
6,145
Lausanne
NiBi Arto 85E
Since 2012
First time I'd seen this idea of using bread crates to help in the mud, makes sense.
Just a thought but in the aquarium hobby we use this stuff a lot:
it's called pond egg crate and will easily take a few tons being driven over it
It's comes in sheets that are approx 27 x 16" so should be big enough and costs around £5 per piece.
The tread depth (thickness) is around 1"
Just a thought ?
359
1,377
Cheltenham
AS Broadway FB
Since 2006
Exactly the same for me. Got mine from the Co-op. Electric jigsaw to cut the sides off but left the base in it's original size. Often use them for parking on when the ground is soft but have used them in anger when we got stuck and they work a treat. They are also useful for door mat when on a grass pitch.
RogerThat
1,128
991
North West
PVC
I'm missing something here (which isn't a new thing lol), why do these not just get pressed in to the grass and sink as you drive over them?
DuxDeluxe
14,657
72,615
Planet Zog
A woosh bang van
since 2008
They do a bit, but also spread the load enabling the tyre to grip something other than mud. They worked at Stratford a few times for various people. I never cut mine in half, though - we keep the full size bases
O
Old Soldier
I managed to get some from the school kitchen where I worked. Only needed to use them once and they worked fine, infact the bread helped to soak up the water. I did find however that the Hovis ones seem to work better on short steep hills, and as for cutting them up, well a bread knife..naturally!!::bigsmile:
11,862
42,816
Planet Earth
A van
Over 25 year's
Just a thought ?
And probably better than stolen bread crates
Bill
Reactions: GJH
1,910
3,886
Shropshire
McLouis Tandy 640+
Since 2014
Or Ground Guard tiles at £4 each from Toolstation. Very tough. You've only got to spend £10 to get free carriage.
1,117
606
Halifax
A Class Rapido 9097F
June 2016
Was looking at these myself we have a toolstation in town :)
Dogeared
430
450
Blackburn
Eldiss autoquest 155
Since 2011
4 from tool station just arrived, look good and quite light, just hope we don't need them Now!
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
A bread crate lashed to the roof rack can be a good way of keeping smaller items stowed out of the way securely.
Lashed to your head it can also make a cheerful novelty hat.
magicsurfbus
4,673
10,127
NW England
Since 1997
I've got some similar items to install in our front lawn for when we park the MH there - they look pretty solid to me, but they're bulkier and heavier than Fiamma sand mats.
maz
Jan 26, 2011
4,460
7,737
Bizeljsko, Slovenia
N+B Arto
Since March 2011
I was looking at these but they're 38mm high with a straight up edge. Suspect my van would just push them along the grass rather than climb on top of them. Has anyone actually used them as grip mats?
1,117
606
Halifax
June 2016
Managed to get several recently from a local bakery. Just made 4 sets of mats
Ain't angle grinders and a couple of files awesome. Would have cost me circ £80 to get purpose built ones probably more depending on what I went for. All it cost was a cheeky question at bakery and an hour of my time.
