Brake vacuum pump question (2 Viewers)
Dec 12, 2010
5,410
21,560
Cumbria
since 2011
Would that be tough enough with hot oil sloshing around and fair bit of torque? I can produce an AutoCAD drawing if necessary.
It is quite tough stuff although it doesn't have the fibres through it like tufnel and it's the only non metallic stuff I've got in my garage. Worse case scenario is it would probably crack across the "keyway" section, but it's maybe worth a try ?
AutoCAD, I'm more the "back of a fag packet" type :LOL: As long as I don't need the programme to open it I should manage. I've a lathe and mill in my garage and been involved in engineering and "making stuff" for over 40 years.
HotBlue
HotBlue
21
Barnet
Fiat Ducato Motorhome
Ok, so I'm showing off a bit - I only got AuotCAD a couple of months ago and just about getting the hang of it but it will export "proper" pictures wot everyone can look at and copy on to the back of a fag packet for safe measure! :)
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
