Brake light seals
Discussion in 'Motorhome Chat' started by haddy, Jan 4, 2016.
  1. haddy
    haddy Funster
    Oct 12, 2015
    80
    34
    Tyldesley
    Bought a Hymer B644 in September 2015 after a few week at home left on the drive I discovered a bit of water on the rear window after we had a heavy downpour so decided to investigate more to see where the water was coming from we discovered it was coming though the sealant on the brake light at the top of the van I couldn't believe how much sealant was holding the light in just be aware a lot of these motorhome manufactures scimp on sealants around lights & bike racks motorhomes are like boats when you start drilling holes in them it's all been sorted now & put back to normal here the results of the water damage
  2. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,363
    3,625
    Newbury , West Berkshire
    And I thought it was only British built motorhomes that leaked from poor workmanship..oh dear time for a rethink.
  3. haddy
    haddy Funster
    Oct 12, 2015
    80
    34
    Tyldesley
    Here a few more pics putting it all back together & last pic is how it looks now & 100% dry now
  4. haddy
    haddy Funster
    Oct 12, 2015
    80
    34
    Tyldesley
    It must have been leaking for some time with the state of it but we couldn't see any evidence of leaking when we bought it or damp.
  5. scootir706
    scootir706
    Oct 26, 2015
    25
    36
    Ayrshire Scotland
    Ouch!!!! Totally understand where your coming from.I started some damp repairs myself a few weeks ago and posted some pics,Ive found more damage as ive went along,What started as the two rear bottom corners has turned into a full strip out of one side to repair roof side timbers where the side joins the roof.will post some pics as been taking plenty as ive went along,From what i can see the problem is a poorly fitted roof sheet which runs off by about 10mm from front to rear so the wood at rear is not covered by much of the sheet and poorly sealed.Id say the worst is over now as ive got all the rotten wood out and just started fitting in new wood.Can i ask what sealer you have been using?Ive been experimenting with a few different ones.Will post pics soon.
  6. haddy
    haddy Funster
    Oct 12, 2015
    80
    34
    Tyldesley
  7. haddy
    haddy Funster
    Oct 12, 2015
    80
    34
    Tyldesley
    I use silks flex adhesive it's marine sealant there's also a sealant called stickall witch is very good stuff as well you can buy either off eBay
  8. scootir706
    scootir706
    Oct 26, 2015
    25
    36
    Ayrshire Scotland
    Ive been using tigerseal which i have used before in truck repairs and is very good,,,,,just got to warm the tubes up a bit to get a good flow,also tried some cv seal from a caravan dealer and bought some evostick ultraflex i think its called frm bnq to try.Biggest problem has been the great Scottish weather as i havnt got the van indoors but i do what i can weather permitting then seal everything up with duct tape which is cheap from b&m homestores.Where did you get your plywood from.........every board at bnq seems warped to excess!!!
  9. haddy
    haddy Funster
    Oct 12, 2015
    80
    34
    Tyldesley
    I bought my board from B&Q warehouse seemed OK
  10. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,292
    2,595
    Surrey
    Well I'm glad to see it isn't only me who's been fixing leeks in this heavy rain. Got to the van on Sunday afternoon (Swift Sundance 630L), to discover a huge puddle of water on the dinette table!
    I thought I'd fixed all the leaks, so back to the drawing board again. So this time I used drastic leak detection methods! I installed a brother in law inside the van whilst I pointed the hose on full pressure to various points on the roof. The leak was under one of the drain cowls, which had to be cut off, and then I discovered the extent of the poor design! Anyway, the good news is that the timber, although damp, is fine, just took me ages to rebuild the internal roof. 2 tubes of Silka Flex one stab in the finger from a Stanley knife and 5 hours later, I believe the leek is now fixed.
    I am sitting in the van right now, and the rain is torrential outside, and so far, it is all dry :D
    • Like Like x 3
  11. haddy
    haddy Funster
    Oct 12, 2015
    80
    34
    Tyldesley
    :):):cool::cool::cool:
    it's a good feeling when you think you've solved the problem.
    • Like Like x 3
  12. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,292
    2,595
    Surrey
    Indeed, been here before though, holding my breath now to see if it really is fixed!!
    I will have to get the photos up, the design of the Sundance is bound to fail, the drain cowl covers a joint from the overcab, the roof and the sidewall. All the gunk that goes in there causes the sealant to rot, eventually it WILL leak! And you can't clean it properly!
  13. Badknee
    Badknee Funster
    Aug 25, 2014
    3,708
    15,892
    notloB
    Just re-sealed my big roof light but the weather has been a nightmare. Big thanks to @edgy for helping me out. (y)
  14. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,292
    2,595
    Surrey
    OK, here goes, this is after I dug out all of the rotten sealant you can see all the holes here:
  15. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,524
    5,616
    West Sussex
    Difference is that is an old Hymer, British vans come out of the factory leaking and will have disintegrated by the time they reach the age of that Hymer.:D
    • Like Like x 3
  16. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,363
    3,625
    Not quite what I am hearing about the newer European vehicles..i agree the old hymers etc were built by craftsmen ,but like everything else now all is down to profit and corners ate being cut by ALL manufacturers..which is a crying shame when you spend so much money on your dream vehicle ..
    • Like Like x 2
  17. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,524
    5,616
    West Sussex
    I've have had 2 new Hymer's last one 2008, current one 2014, no problems with build quality. Like all vans they are using lighter construction to keep the weight down due to modern chassis being heavier.
    Not much point in building a heavier more solid van if it hasn't got a useable payload, oh sorry I forgot British manufacturers manage it.:)
  18. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,363
    3,625
    So much for promoting your own country's products which in my opinion are just as good as anything of the similar type bought in Europe....I buy British because I am proud to be British and proud of our manufacturing.....if I have broke any rules @Jim. Please delete,but I really am getting a tad pi@aed off with British made motorhomes are rubbish attitudes...
  19. scootir706
    scootir706
    Oct 26, 2015
    25
    36
    Ayrshire Scotland
    Hi all thought id share some pics of my water leak woes.Getting on top of it now but im sure you will agree they make some scary viewing.As you will see in the pics the roofskin has been appallingly fitted and couldnt do anything else but leak.Must have been leaking from new w 20160102_135505.jpg 20160102_135518.jpg 20160103_115630.jpg 20160103_143817.jpg 20160103_143829.jpg 20160103_145839.jpg 20160103_145848.jpg 20160103_115642.jpg hen you see the state of the timber.
  20. scootir706
    scootir706
    Oct 26, 2015
    25
    36
    Ayrshire Scotland
    Oops maybe should have made the pics a bit smaller............next time:) You can see how much the roofskin runs off from front to rear,,,,,starts at a few mm at front which i guess is normal to hardly covering the timber at the rear..........oh and its a ci make lol
    • Like Like x 1
