Brake Light Fault - any suggestions? (1 Viewer)
Wombles
10,802
11,106
SW England
Van Conversion
A few years now
Our Chausson Best Of 04 on Ford Transit chassis has a recurring brake light fault - solved briefly by Ford dealership replacing fuse but now flickering & faint again within days! It's going back to Ford tomorrow but after 2 days fault finding the first time only for it to happen again we are concerned that this recurring fault might not be solved this time either.Has anyone else had a similiar problem with a Chausson or other coachbuilt on a Transit chassis?
chatter
3,689
937
cheshire
5th wheel
poss bad earth somewhere along the line i would of thought or maybe a wrong bulb, but then again me being a mere female I could well be wrong
794
826
Near Truro, Cornwall
Brake light fault
Hi, although our van is on a Fiat chassis, we had a similar problem last year just before setting off on a nine week tour of Spain, Morocco and France. The dealer we bought the van from, who carried out the pre tour service, said it was probably due to road muck coming off the rear wheels and lodging on and around the wiring and connectors feeding the rear light clusters, which he said was a common failing on Hymers. He rewired the clusters but the problem kept coming back, and worse, it was intermittent. It was only when we were in Morocco and it happened again that one of the tour guides identified the real problem. At the bottom of the bulb holder behind the rear lenses is a small spring and on our 6 year old van, the spring blade had weakened over time, breaking the electrical contact. The solution: take a small bladed tool (penknife or screwdriver) and lift the sprung blade, then replace the bulb. It worked and the problem has not returned.
Don't know if this will help you, but it may.
If anyone out there knows where I can get hold of replacement bulb holders for a 2006 Fiat based Hymer A class rear light cluster I'd like to hear from them, because I'm sure the solution will not last forever!:thumb:
SueBaz
124
227
Nr Canterbury, Kent
C class
Since February 2012
Hi, although our van is on a Fiat chassis, we had a similar problem last year ..........:
Hi Wombles
Think this is a good place to look. Our Fiat Burstner has the exact same problem (with the same symptoms)with the right hand rear indicator. .....and likewise finding a bulb holder to match in Portugal where we are at present could prove to be a challenge!
Good luck with yours
Barry and Sue
Xabia
1,186
821
Rural Nottinghamshire and Spain
Since 1996
I had a similar problem on my 2007 B544SL. Discovered that the problem was due to the circular part of the fitting into which the bulb fits had somehow opened itself up marginally causing an intermittent earthing problem. Tightened them up very gently with pliers and reinserted the bulbs, sprayed with WD40 and no further problems. I also took the opportunity to disconnect the connector between the light cluster and the loom, clean with appropriate cleaner, reassemble and then protect with self amalgamating tape to prevent any road dirt from affecting this area in future.
Mike
Trikeman
1,649
3,095
Wilds of Ceredigion.
AT 634 Apache.
Since 2011.
If all the excellent suggestions above don't bare fruit, have a look at your connection plug, it's cable length and where it joins into the loom - that's if you have towing electrics.
I have forgotten how many times I have seen this and although not a 'first port of call' and often overlooked, I would check this area as a matter of course.
Hope it helps.
Regards,
Trikeman.:winky:
Oct 28, 2013
490
443
Lincoln
Van Conversion
If the rear light clusters are mounted to a fibreglass body the earthing is likely to be the issue.
One of my number plate lamps was out at the weekend.
I tried a new bulb but to no avail so I ran in a separate earth straight to the chassis and it's fine.
It may be worth running in new earths to all the lamps individually and taking them back to one new earth point just so I have no problems out on the road where it's not so easy to fix.
Wombles
Wombles
10,802
11,106
SW England
Van Conversion
A few years now
All sorted!
Thank you for the suggestions - turned out to be poor insulation on 2 terminals on rear upper brake light which also affected the lower brake lights. Thought that maybe there was some intermittent fault/flaw on Ford chassis / Chausson coachbuilts so relieved to know this is not the case.:Smile:
FULL TIMER
795
717
NORWICH
SELF BUILT IVECO 75E17
BEEN BUILDING THEM FOR 32 years
If your vehicle uses the original transit light clusters or even the original connectors I would look at the earth connection in the connector transits are known for these corroding/burning away Ive changed several on ambulances lately, Renaults also suffer the same. I don't know how new your vehicle is but I have two mates both had pretty new fords one a focus the other a transit connect both suffered total light failure turned out to be the ECU 's . hopefully and more likely yours will just be bad earths.
