boyart23 (1 Viewer)
boyart23
31
8
uk
Caravan
since 2002
:Sad: Hi,
My 2008 Autocruise Starspirit is having waterworks problems! Sometimes when a tap is turned on (bathroom shower or domestic sink) water will flow. Other times no flow, press the toilet flush and water flows into the loo and from an open tap water also flows. Any tips on what might help with this problem?
boyart
Jul 28, 2010
1,710
617
The world
Small car
:Sad: Hi,
boyart
one stick of DYNOMITE securely fitted on any tap fitting
that should solve the problem no trouble ::bigsmile:
any more would just be over kill :Doh:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
:Sad: Hi,
boyart
Looks like a bad electrical joint. Every tap has a switch when you open it, this turns on the pump. Same applies to the toilet. So the toilet always turns on the pump but the taps do not -- simples -- just find that joint.
B
boyart23
31
8
uk
Caravan
since 2002
Pressure seitvh/sdjuster
Thank's B-well for the tip. Can't see anything that looks like a pressure adjuster, just inlet and outlet and elec comnections.
Boyart23
