Boxer radio
Discussion in 'Motorhome Chat' started by motorhomewave, Jan 1, 2012.
  1. motorhomewave
    motorhomewave Read Only Funster
    Jul 17, 2009
    138
    51
    We have a 3 year old Boxer, no not the dog ! Peugeot, that from new has had the worst radio and reception I have ever known. The CD part of it is fine but the FM radio cuts out in poor reception areas (lamost anywhere) and LW/MW is nearly useless. The van has no detectable aerial on it and I wondered if it actually has one or not, it's an Elddis 120 anybody know ? Strangley we also have a Peugeot car, it's radio is none too brilliant either ! :Doh:
  2. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,875
    23,583
    Narrfoook
    We had the same issues.
    Two possible scenarios and neither great !
    1) If you have the facelift pug ( 2007 on ) then there is every chance the aerial is in a mirror
    Total crap idea !
    2) If you have a pre-facelift pug then chances are you have no aerial at all !! The converter will have simply removed the thing leaving the wire in place just to confuse the issue
    Either way, the only real answer is to go to a car shop and get a proper aerial ( and I mean proper, not one of those stick on the inside of the windscreen things ) and mount it on the wing.
    It is not a bad job on either model but do make sure you remove all the pint from the inside of the wing so it makes a good earth ( else you will be back where you started from again ! )
    Once fitted coat the inside with a bit of underseal or similar to ensure no rust has a chance !
    • Like it Like it x 1
  3. motorhomewave
    Jul 17, 2009
    138
    51
    Thanks for that, will take a trip to a specialist and dig further into emty pockets !
  4. Jaws
    Sep 26, 2008
    18,875
    23,583
    Narrfoook
    Where abouts are you ? If you are close enough I would be happy to either help or do it for you .. You should be able to get an aerial for £5 to £25.00
  5. motorhomewave
    Jul 17, 2009
    138
    51
    Quite a way from Norfolk, North Yorkshire, only visit Norfolk once a year for the summer show in early July. Thanks for the offer anyway, will get myself a big drill, ten pound lump hammer and to comply with health and Safety, steel capped boots, goggles, safety:BigGrin: helmet and steel mittens, job done.
  6. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    dont forget to put a bit of masking tape on the paint before drilling the hole as it helps to stop the drill skating all over the panel.
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    and dont drill the hole until you are absolutely sure you can access the back of it to tighten the fittings.
    also, use a circular hole cutter...not a regular twist bit, unless its a very small hole. the wing steel is like tinfoil and will deform as you drill using a twist bit.
    i had a 2002 Ducato base and had to remove the entire o/s wing to fit an aerial.
    not a difficult job, but time consuming.
  8. poppys
    poppys Read Only Funster
    May 8, 2010
    166
    41
    Norfolk
    The radio on my Boxer is the worst one Ive ever had on any
    vehicle,its got a wing mounted stubby black ariel so I think you may have to accept bad reception or change the radio.
  9. Jaws
    Sep 26, 2008
    18,875
    23,583
    Narrfoook
    No... it will be that crappy aerial again I am afraid..
    You cannot beat physics. You can kid it, but you cannot beat it.
    Replace the thing with a proper aerial and all should be well
    It is VERY VERY rare for the front end ( the actual bit that does the receiving ) to go 'deaf'.. Yes, it does happen but as said, incredibly rare
  10. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,518
    Tyne & Wear, sometimes..
    I have the post 2007 Boxer and previously I had the 2006 Boxer model. Both have the stubby aerial on the offside wing.
    Both had truly crap radio reception, particularly on AM, and both shared the same crappy radio.
    Changing the radio itself actually made a real substantial improvement.:thumb:
    I still have to get around to changing the aerial to improve things even more...
    Callum
  11. Bailey58
    Bailey58 Funster Life Member
    Jun 23, 2010
    6,700
    10,394
    Norfolk and Toftir.
    Think my radio (Pug 2007) has been changed but it's still crap with a screen mounted ariel. And another thing, I've never looked at the handbook but the steering wheel switches suggest there are controls for the radio although they don't work on the current installation, or would they be for a phone?
  12. callumwa
    Jan 16, 2011
    4,113
    4,518
    If the original radio has been removed that's most probably why the steering wheel radio/cd/volume wheel controls will not work.
    There is a lead at the back of the radio, which comes from the steering wheel controls, which plugged into the original radio for the remote function.......
    Most replacement radios will not be compatible...... but the radios should normally be better, our is...
    Callum
  13. Jaws
    Sep 26, 2008
    18,875
    23,583
    Narrfoook
    Unless the replacement radio has the plug ins for the steering wheel controls they aint gonna work :Sad:
    Callum, if you fitted a new radio then yep, the front ends have improved dramatically over the past few years and knowing Pug they are still fitting the same units they fitted in chariots !
    But it is always a LOT cheaper to replace an aerial that a radio.. and a went lollipop on a bit of string is often better than those horrid rubber ducky things !
    • Like it Like it x 2
  14. Welsh girl
    Welsh girl Funster Life Member
    Nov 7, 2009
    2,794
    1,361
    living the dream.
    Strangely the peugeot boxer we had, had a marvellous radio in it but this Fiat we now have is terrible with no reception in places and we put it down to being a DAB radio with rubbish reception so only use the cd now, there is no aerial visible either.
  15. Jaws
    Sep 26, 2008
    18,875
    23,583
    Narrfoook
    I really do fail to see how they expect digital radio to be of any real use in cars unless the transmitters outputs are more than doubled in power ( radio waves are like light and gains are logarithmic when you talk about VHF and above frequencies*. A 3.8dB gain, i.e. double the output, in ideal conditions is likely to give an extra 12.5% range increase )
    * Line of site transmission
  16. BobProperty
    BobProperty Read Only Funster
    May 20, 2010
    272
    32
    Stockport
    You can get adapters to connect the existing wiring to the head unit to allow the original controls to work.
  17. rangitira
    rangitira Funster
    Jun 30, 2010
    6,478
    13,571
    Cornwall
    I've got the same cab as your pug, it's a Fiat (badge engineering) Had a lot of trouble with the Radio. Couldn't find the Aerial, recently fitted a Windscreen Aerial.
    No drilling! No phaffing about, Just remove 8 screws Job done in an hour, that included a cup of coffee.
    Just got back from a Rally with the MCS CC&C Radio reception A1 all the way there and back.:thumb::thumb:
