boxer gearbox oil
Discussion in 'Peugeot' started by betterthenatent, Mar 26, 2011.
  1. betterthenatent
    betterthenatent Read Only Funster
    Aug 23, 2010
    38
    Hi can anyone tell me where to locate the gearbox oil filler and drain plug on a 2005 2ltr hdi .
  2. ticktok
    ticktok Read Only Funster
    May 13, 2010
    41
    Kent (South Coast)
    Hi,
    As far as I am aware if it is the same as the slightly earlier one there isn't a level plug or dipstick or come to that a proper filler.:Sad: If there are signs of the gearbox leaking you have to drain the oil and refill with the correct amount of oil via a breather right on top of the gearbox, if it is the same as the one I had it is almost impossible to see but can be felt, it has a plastic cap which can be pulled of and the oil put in very slowly with a plastic hose connected to a funnel, don't forget to replace the cap as the box fills up with water from the NS wheel spray if forgotten!
    Hope this helps
